Guest SSID web auth issue
a_naipaul
Frequent Visitor
Frequent Visitor
Hi guys,
If possible, please could I have your assistance.
We currently have Access Points which are in flex connect mode and are split across 2 x Wireless controllers (5508) – The APs are in high availability mode and will fail over to the secondary controller in the event of failure to the primary – Please note the controllers are located in different geographic regions.
An issue has occurred with the primary controller and the APs have failed over to the secondary – I have checked the controller and can see they are now located on the secondary. However, for a specific SSID which is a guest network, users are not able to login to this.
The guest network utilises web auth with a splash page login – I can confirm that the SSID works because I can login to it, however, my aps have not had to failover as the secondary controller is my sites primary.
I was wondering if there could be a case that the users are being redirected to the primary “failed” controller, as opposed to being redirected to the splash page on the secondary controller – which is why they are not able to login….
Please let me know if that could be a possibility or if it that cannot happen… any help will be appreciated! 😊
7 Replies 7
patoberli
Do you maybe not use the same VLAN for your local guest-side compared to the remote guest side?
Depending on your configuration (Flexconnect, Local, SSID, …) that might be an issue.
Thank you for the reply – The APs are built in flex connect mode, so the local vlans are not dependent on which controller they are connected to.
In that case I suggest you check the flex group for that ssid if everything is correct.
Do the clients get a valid ip address?
From doing a sanity check on the controller, the flex connect groups look ok to be honest.
The issue is that when the users are looking to connect to the guest URL, they are redirected to the splash page - Once they try to logon to the splash page using valid guest credentials, the web page spins goes blank and just goes back to the original login splash page..
I was initially thinking this could be an authentication error - However, I tried the connectivity myself and the credentials worked fine.
So I was thinking are they being redirected to the defective controller still? Not sure if that is possible....
Do you use the wlc guest portal or a third party one?
The guest portal which is on the WLC, we do not use a third party one
Haydn Andrews
confirm the following are the same on both WLCs
WLAN Settings
WebAuth page - if using local web auth
ISE Setting if using CWA or ISE for the splash page
Flexconnect groups and VLAN mappings
*****Help out other by using the rating system and marking answered questions as "Answered"*****
