Guest tunneling security problem
Thibault BRISSE
Level 3
Level 3
I configured guest tunneling between 5508 (internal LAN) and 2504 (DMZ) and it works perfectly. However when the tunnel is down guest users are
associated to the management interface on the 5508, I only have to configure an IP adress and a default gateway on a guest user to
be routed on the internal network.....So, there is a security problem in my network architecture.
Do you have advice to avoid this problem ?
Best regards,
Thib
Rasika Nayanajith
You can create  a "dummy/unrouted" interface on your 5508 & map that to guest SSID instead of management interface.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Rasika
Thanks a lot. I though it was necessary to use the management interface.
