Guest Wireless client not getting IP addresses
keith.k.quaye
WLC 5508 as anchor  running 7.0.116.0  locally configured DHCP scope. Scope has been enabled.  There are 2 Foreign controllers in different locations Mobility ggroups have been configured   and there is communication between them  I am able to ping , mping and eping.  I have gone through my configuration but can't find what is missing.
3 Accepted Solutions
Hi Keith,
It looks like we have a misconfiguration on your anchor controller configuration on the WLAN. To properly anchor a WLAN, the foreign WLC should point the anchor, and the anchor should only point to itself.
For example:
10.12.30.114 is your foreign
10.12.130.114 is your anchor
On the Foreign WLC, define an anchor pointing to 10.12.130.114
On the Anchor WLC, define the anchor pointing only to itself, 10.12.130.114 (local)
It seems we have 2 entries on your anchor, so I think the anchor is getting confused and might be trying to tunnel traffic again.
-Pat
pcroak
One additional note -- the WLAN config needs to match between the WLCs, we have DHCP required (under advanced tab) disabled on the foreign, but enabled on the anchor.
If we correct these 2 things I think it should work!
-Pat
Hi Keith,
I would also suspect the firewall. Pings sourced from the WLC will be sent from the management address of the anchor WLC. Your wireless clients are in a different subnet, so you would want to make sure that the appropriate rules are configured on the firewall for that subnet.
You could test this if you have another device on the guest subnet inside the firewall, if so, try pinging that from a wireless client.
-Pat
11 Replies 11
pcroak
Hello Keith,
First, we should double check all of your WLAN settings between the Foreign and Anchor WLC. From the CLI "show wlan x" where x is the WLAN ID.
Next, we will want to capture a client debug while this devices tries to connect. We will want to capture this on both the foreign WLC and the anchor WLC:
debug client xx:xx:xx:xx:xx:xx
Where xx:xx... is the mac address of your test clients wireless interface. Please capture this output for further analysis.
-Patrick Croak
Wireless TAC
keith.k.quaye
I am pasting the debug and show wlan  info below  the first is for the  foreign controller
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.09.23 07:51:16 =~=~=~=~=~=~=~=~=~=~=~=
*apfReceiveTask: Sep 22 23:30:29.265: 00:21:5d:a9:2b:a4 Deleting mobile on AP 08:17:35:31:1c:90(0)
*apfReceiveTask: Sep 23 12:51:08.488: 00:21:5d:a9:2b:a4 0.0.0.0 DHCP_REQD (7) DHCP Policy timeout. Number of DHCP request 0 from client
*apfReceiveTask: Sep 23 12:51:08.488: 00:21:5d:a9:2b:a4 0.0.0.0 DHCP_REQD (7) Pem timed out, Try to delete client in 10 secs.
*apfReceiveTask: Sep 23 12:51:08.488: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station: (callerId: 12) in 10 seconds
*osapiBsnTimer: Sep 23 12:51:18.488: 00:21:5d:a9:2b:a4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Sep 23 12:51:18.488: 00:21:5d:a9:2b:a4 apfMsExpireMobileStation (apf_ms.c:5009) Changing state for mobile 00:21:5d:a9:2b:a4 on AP 08:17:35:31:1c:90 from Associated to Disassociated
*apfReceiveTask: Sep 23 12:51:18.488: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station: (callerId: 45) in 10 seconds
*osapiBsnTimer: Sep 23 12:51:28.488: 00:21:5d:a9:2b:a4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Sep 23 12:51:28.488: 00:21:5d:a9:2b:a4 apfMsAssoStateDec
*apfReceiveTask: Sep 23 12:51:28.488: 00:21:5d:a9:2b:a4 apfMsExpireMobileStation (apf_ms.c:5132) Changing state for mobile 00:21:5d:a9:2b:a4 on AP 08:17:35:31:1c:90 from Disassociated to Idle
*apfReceiveTask: Sep 23 12:51:28.489: 00:21:5d:a9:2b:a4 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [08:17:35:31:1c:90]
*apfReceiveTask: Sep 23 12:51:28.489: 00:21:5d:a9:2b:a4 Deleting mobile on AP 08:17:35:31:1c:90(0)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Adding mobile on LWAPP AP 08:17:35:31:1c:90(0)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Association received from mobile on AP 08:17:35:31:1c:90
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Changing ACL 'none' (ACL ID 0) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1621)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Applying site-specific IPv6 override for station 00:21:5d:a9:2b:a4 - vapId 1, site 'default-group', interface 'management'
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Applying IPv6 Interface Policy for station 00:21:5d:a9:2b:a4 - vlan 30, interface id 0, interface 'management'
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 STA - rates (8): 130 132 139 150 12 18 24 36 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state AUTHCHECK (2)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 L2AUTHCOMPLETE (4) DHCP Not required on AP 08:17:35:31:1c:90 vapId 1 apVapId 1for this client
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 08:17:35:31:1c:90 vapId 1 apVapId 1
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 apfMsAssoStateInc
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 apfPemAddUser2 (apf_policy.c:223) Changing state for mobile 00:21:5d:a9:2b:a4 on AP 08:17:35:31:1c:90 from Idle to Associated
*apfMsConnTask_7: Sep 23 12:51:30.795: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station: (callerId: 49) in 1800 seconds
*apfMsConnTask_7: Sep 23 12:51:30.796: 00:21:5d:a9:2b:a4 Sending Assoc Response to station on BSSID 08:17:35:31:1c:90 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_7: Sep 23 12:51:30.796: 00:21:5d:a9:2b:a4 apfProcessAssocReq (apf_80211.c:5241) Changing state for mobile 00:21:5d:a9:2b:a4 on AP 08:17:35:31:1c:90 from Associated to Associated
*DHCP Socket Task: Sep 23 12:51:30.920: 00:21:5d:a9:2b:a4 DHCP received op BOOTREQUEST (1) (len 308,vlan 30, port 13, encap 0xec03)
*DHCP Socket Task: Sep 23 12:51:30.921: 00:21:5d:a9:2b:a4 DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Sep 23 12:51:34.871: 00:21:5d:a9:2b:a4 DHCP received op BOOTREQUEST (1) (len 308,vlan 30, port 13, encap 0xec03)
*DHCP Socket Task: Sep 23 12:51:34.871: 00:21:5d:a9:2b:a4 DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*DHCP Socket Task: Sep 23 12:51:43.998: 00:21:5d:a9:2b:a4 DHCP received op BOOTREQUEST (1) (len 308,vlan 30, port 13, encap 0xec03)
*DHCP Socket Task: Sep 23 12:51:43.998: 00:21:5d:a9:2b:a4 DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*DHCP Socket Task: Sep 23 12:51:58.456: 00:21:5d:a9:2b:a4 DHCP received op BOOTREQUEST (1) (len 308,vlan 30, port 13, encap 0xec03)
WLAN Identifier.................................. 1
Profile Name..................................... calguest
Network Name (SSID).............................. calguest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 2
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Bronze (background)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Global Servers
Accounting.................................... Global Servers
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Enabled
H-REAP Local Switching........................ Disabled
H-REAP Local Authentication................... Disabled
H-REAP Learn IP Address....................... Enabled
Client MFP.................................... Optional but inactive (WPA2 not configured)
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID IP Address Status
1 10.12.130.114 Up
Next is for the  anchor
Radius Servers
Security
1 10.12.130.114 Up
Hello Keith,
From the looks of it, I think you may have accidently pasted the foreign controller output twice. Could you please confirm that you also have the anchor WLC output?
-Pat
>> I assume you have the DHCP pool on the management interface!! if not please create one since ur pointing ur anchor to the management interface.
>> I have seen this issue many times on the customer network while troubleshooting!! When ever i see the logs..
and when the configuration is correct, correct in the sense bulls eye!! then deleting the WLAN on the anchor and the foreign and then reconfiguring the same helped every single time in getting the issue resolved..
U can try the same, it may help OR may open up a TAC case or lets wait for Expert PATs reply!!
Surendra
Surendra BG
Here is the Anchor  info
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.09.23 07:50:30 =~=~=~=~=~=~=~=~=~=~=~=
*mmListen: Sep 23 07:51:31.236: 00:21:5d:a9:2b:a4 Adding mobile on Remote AP 00:00:00:00:00:00(0)
*mmListen: Sep 23 07:51:31.236: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station:  (callerId: 69) in 1 seconds
*osapiBsnTimer: Sep 23 07:51:32.220: 00:21:5d:a9:2b:a4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Sep 23 07:51:32.220: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Deleted mobile LWAPP rule on AP [00:00:00:00:00:00]
*apfReceiveTask: Sep 23 07:51:32.221: 00:21:5d:a9:2b:a4 Deleting mobile on AP 00:00:00:00:00:00(0)
*mmListen: Sep 23 07:51:32.236: 00:21:5d:a9:2b:a4 Adding mobile on Remote AP 00:00:00:00:00:00(0)
*mmListen: Sep 23 07:51:32.236: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station:  (callerId: 69) in 1 seconds
*osapiBsnTimer: Sep 23 07:51:33.220: 00:21:5d:a9:2b:a4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Sep 23 07:51:33.221: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Deleted mobile LWAPP rule on AP [00:00:00:00:00:00]
*apfReceiveTask: Sep 23 07:51:33.221: 00:21:5d:a9:2b:a4 Deleting mobile on AP 00:00:00:00:00:00(0)
*mmListen: Sep 23 07:51:33.236: 00:21:5d:a9:2b:a4 Adding mobile on Remote AP 00:00:00:00:00:00(0)
*mmListen: Sep 23 07:51:33.236: 00:21:5d:a9:2b:a4 Scheduling deletion of Mobile Station:  (callerId: 69) in 1 seconds
*osapiBsnTimer: Sep 23 07:51:34.220: 00:21:5d:a9:2b:a4 apfMsExpireCallback (apf_ms.c:608) Expiring Mobile!
*apfReceiveTask: Sep 23 07:51:34.220: 00:21:5d:a9:2b:a4 0.0.0.0 START (0) Deleted mobile LWAPP rule on AP [00:00:00:00:00:00]
show wlan
Number of Active Clients......................... 0
Interface........................................ dynamic-calguest
--More-- or (q)uit
DHCP Address Assignment Required................. Enabled
Radius Servers
--More-- or (q)uit
Security
--More-- or (q)uit
1           10.12.130.114         Up
1           10.12.30.114          Up
Hi Keith,
For example:
-Pat
pcroak
-Pat
Thanks  Pat ,  You hit it the nail right on the head.  Stay tuned  a  couple more questions  on the way. Once again thanks for your help
Ok  I can  get an an IP address now but I cannot get to the internet.  I am thinking its the Firewall  but want to make sure there is nothing  I am missing.  I can ping the external DNS server  8.8.8.8 from the  anchor but I can't ping it from the  client laptop.
Hi Keith,
-Pat
Pat once again  thanks. You confirmed my suspicion there was an incorrect nat rule on the FW  when that was resolved  I was able to get the authentication splash page and  internet access.
