Guest Wireless Not working
I have two controllers running code 6.0.182 and one guest controller with same version.
I can see the tunnel UP(Both control and data path) in both controller.
Guest users are authenticated by web authentication.Suddenly guest users become too slow to access internet.Web authentication is successfull.But its too slow to access internet.Did anyone face the same issue.Pls reply me at the earliest.
Danish Ahammed
37 Replies 37
Hi Nicolas,
It was typo error , Vlan 40 and Vlan 1 are not on the same subnet.
I just want to know , if i need to create another default Gateway for Vlan 40 on SWITCH.
I know that there is only one default gateway per  AP, which i did. and i have the two Vlans configured already on AP.
My Question is what you mean by Bridging them ; "simply bridging them. One switch somewhere having a vlan interface for both vlan 1 and 40 and a dhcp pool for each subnet."
is it on Switch or AP. And How?
Dak
Here you can follow a detailed config example for IOS AP with 2 VLANs, including the configuration on the L3 switch for the VLAN interfaces and dhcp pools:
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml.
Hope this helps.
Tiago
PS. Next time please open a discussion for your setup as it has nothing to do with the original post..The original post was for LWAPP deployment.
Yours is for Autonomous AP.
I can not open link you sent " http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml. I will need Password to open it. Could you send me other link without Password ?
Dak
Hello ,
 I tried to configures int vlan 40 and enable it with "no shutdwon",
when i check on the interface , it is down dwon
 VLAN40                      10.0.0.18       YES NVRAM  administratively down down    .
Any Help
DAk
As any L3 VLAN, the VLAN needs to be configured on the switch and will only come up if you have it on an interface.
You need to create the vlan, create the vlan interface and add it to the allowed vlan list on the trunk where the AP is connected.
Have you gone through the document i suggested to you?
Did it helped?
Tiago
Hello Tiago,
I appriciate all your effort, i want you to know what i did already and if i am wrong in my configuration let me know  .
On SWITCH I created access Vlan for GUEST and Phone
Int fa0/12
Switchport mode  access
switchport  access vlan 40 >>>>> GUEST VLAN
switchport voice vlan 10 >>>>>>>Phone VLAN
spanning-tree portfast
still Int vlan 40 is still the same ( down down)
Incase  you want more information let me now. the switch is  Cisco 3548 XL
Is that the config of the port where the AP is connected???
Why would you configure a switchport voice vlan there??
Where have you seen to configure an access port where you have the AP connected  on the document i sent you?
Can you just follow the document?
The config on the port where the AP is connected should be something like:
Switch#configure terminal
Switch#interface fastethernet 0/10
!−−− Enter the interface mode for Fast Ethernet 0/10
Switch#switchport mode trunk
!−−− Configure the switch port mode to trunk mode.
Switch#switchport trunk encapsulation dot1q
!−−− Configure the encapsulation on the switch port to dot1q.
Switch#switchport trunk native vlan x
!−−− Configure the native VLAN as VLAN x.
Switch#switchport trunk allowed vlan add 2,20,30
!−−− Configure the list of VLANs that are allowed on the trunk port.
Switch#switchport nonegotiate
Tiago
Tiago,
No that is not the port AP is going to be pluged in, the configuration was already there before think of AP .I just want to inform you that Guest network or Vlan is already defines in some port. I know that AP port need to be Trunk .which i did already and at the port i allowed all vlans.
dak
Ok, so are those interfaces up?
Can you share with us the output of "sh int status" and "sh vlan"?
Tiago
I will get back to you latter , i am at different site.
Dak
Hello Tiago,
Here is all the info you requested for .But i have not plug AP into any port
are these
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/6,
                                                Fa0/8, Fa0/10, Fa0/12, Fa0/13,
                                                Fa0/14, Fa0/17, Fa0/21, Fa0/22,
                                                Fa0/23
2    DATA_rfarafarrfa                 active
20   VOICE_voippppp                   active    Fa0/5, Fa0/15, Fa0/16, Fa0/18,
                                                Fa0/19, Fa0/24
21   VOICE_Prorama12                  active
50   Weada                            active    Fa0/7
51   VB_PErafaraf_1                   active    Fa0/9
40   GUEST                            active    Fa0/20
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Fa0/8                      notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/9   XXXXXXXXXXXX1      connected    51         Full     100 100BaseTX/FX
Fa0/10                     notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/11  PC + PHONE         connected    trunk    A-Full   A-100 100BaseTX/FX
Fa0/12                     notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/13  CCCCCCCCCCCC       notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/14  PPPPPPPPPPPPP      notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/15  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/16  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/17  cravafabsbs nic 2  connected    1          Full   A-100 100BaseTX/FX
Fa0/18  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/19  top PC             notconnect   20         Auto    Auto 100BaseTX/FX
Fa0/20  VLAN 40 GUEST Inte notconnect   40        Auto    Auto 100BaseTX/FX
Port    Name               Status       Vlan     Duplex Speed   Type
VLAN1                      10.10.1.1     YES NVRAM  up                    up
VLAN40                     10.20.40.1      YES manual administratively down down
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/2            unassigned      YES unset  up                    up
FastEthernet0/3            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  up                    up
I hope these infos are what you want?
So looking at your post it is clear why the VLAN is down...
The VLAN will only come up if the VLAN is active in any port of the switch.
And looking at the output, you only have VLAN 40 assigned to one interface, and that interface is not connected "Fa0/20  VLAN 40 GUEST Inte notconnect   40 " so untill you connect a device to this interface, it will always remain DOWN.
HTH,
Tiago
If this answers your question please mark the question as "answered" and rate it, so other users can easily find it.
i will get back to you . I am  on other site.
Dak
Hi Tiago,
I just want to inform you that the AP can not connect to GUEST .  Here are the information for trouble shooting.
1.
Oct 18 14:17:03.120: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
1aa Associated KEY_MGMT[WPA PSK]
Oct 18 14:17:30.080: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 402b.a1d2.51aa Reason: Sending station has left the BSS
Oct 18 14:17:30.141: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:04.439: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:04.606: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:05.650: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:10.229: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:42.313: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:46.923: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:19:04.485: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
99f Associated KEY_MGMT[WPA PSK]
Oct 18 14:19:18.970: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:19:34.492: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 0024.9f52.c99f Reason: Sending station has left the BSS
Oct 18 14:20:20.041: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:20:50.049: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:21:01.792: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:21:31.799: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:21:45.636: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:22:15.647: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:22:34.543: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
2. show ip int brief :
ocol
VLAN1                      10.21.48.44     YES NVRAM  up                    up >>>>>>>>>>> NATIVE VLAN
VLAN9                     unassigned      YES unset  administratively down down
VLAN40                     10.21.41.2      YES manual administratively down down>>>> GUEST VLAN
FastEthernet0/1            unassigned      YES unset  down                  down
FastEthernet0/2            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  down                  down
3. on AP show ip int brief
ocol
BVI1                       10.10.48.X      YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
Dot11Radio0.30             unassigned      YES unset  up                    up
Dot11Radio0.40             unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
GigabitEthernet0.40        unassigned      YES unset  up                    up
4. Trunk Port configure and AP install in Switch port as well
Building configuration..
Current configuration:
interface FastEthernet0/25
description TRUNK-to- GUEST Wireless
speed 100
switchport trunk allowed vlan 1,40,1002-1005
spanning-tree rootguard
5. Admin User can connect and browse internet ,but the Guest user can not connect.
This is where i need solution>
I read the pdf you sent, and my Configuration is nearly the same. except hat i used TACAC & Radius server.
Dak
