Guestconnect wireless connection is dead slow
s.kanth
After installing Certificate on NGS , Guestconnect wireless connection is dead slow. (takes more than 1 minute to load Splash page ,which is stalled on NGS)
We have another Anchore controller with NGS in DR site. Whenever we pointing WLC to DR Anchor controller ,no issue.
Any help is highly appreciated.
Sri
6 Replies 6
Stephen Rodriguez
Are they using the same NGS? Are there any half duplex links in the path?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
not the same NGS. which was working fine before certificate installation.
Problem started after installing the certificate. then we diverted the traffice to our DR site( no issue here).
The certificate shouldn't cause this, unless there is an issue getting to the Internet to validate the certificate.
It could still be a duplex issue between the NGS and the Internet connection at the non-DR site.
Steve
HTH,
Steve
As I said before, only Guest connect authentication request takes more than 1 minutes(takes more than 1 minute to load Splash page ,which is stalled on NGS) .
Once the auth is successfuly , users can access internet normally.
You want to be certain, sniff the guest traffic and see what is being delayed.
__________________________________________________________________________________________
zappo0305
Are u natted? Could be cert validation issue. Turn off ocsp checking on ur browser c how it goes
