Help decoding error message
770801tvdhaar
Level 3
Level 3
Hi can anyone help me decode what the problem is with this client. Error says 802.1x is required when I'm using WPA/PSK authentication?
I get these error all the time
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Controller association request message received.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Association request received from a client has an invalid RSN IE.(One reason could be mismatch in WPA2 algorithm)
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Received reassociation request from client.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :The wlan to which client is connecting requires 802 1x authentication.
Time :02/26/2009 09:06:18 CET Severity :INFO Controller IP :x.x.x.x Message :Client moved to associated state successfully.
Time :02/26/2009 09:06:19 CET Severity :ERROR Controller IP :x.x.x.x Message :802.1x authentication message received, static dynamic wep supported.
Time :02/26/2009 09:06:21 CET Severity :INFO Controller IP :x.x.x.x Message :802.1x authentication was completed successfully.
Time :02/26/2009 09:06:21 CET Severity :INFO Controller IP :x.x.x.x Message :Client has got IP address, no L3 authentication required.
Time :02/26/2009 09:06:30 CET Severity :INFO Controller IP :x.x.x.x Message :Controller association request message received.
Time :02/26/2009 09:06:30 CET Severity :ERROR Controller IP :x.x.x.x Message :Current load on the radio of this AP is exceeded hence ignoring the request from this client.
16 Replies 16
Depending on code it should be down below the 802.1x key management box.
I've found the info about this bug: CSCsx59156. Sounds something like the problem we have, but we didnt use Wlan Template, we configured with Configure/Controllers in WCS. But the effect may be the same?
