Help needed with configuration- WLC 3504, WAP 1832i, multiple site guest network
I am trying to configure a guest wireless network, for a small number of clients across several sites. I would like to manage the whole deployment from my WLC. All AP's are 1832i's running 8.5.140.0. The GW port on my ISP equipment is 192.168.111.1, on VLAN 11. On my WLC, port 3 is assigned the address 192.168.111.2 VLAN 11 and connected to the ISP's equipment on the port holding the gateway address 192.168.111.1. I want the WLC to handle the DHCP. The way I am doing this is my WAP's associate to the WLC from their respective networks (Different segment for each site). All WAP's are assigned DHCP and properly associate to the WLC using option 43. So one example is I want a WAP located at 192.168.2.36 associated to the WLC at 192.168.1.68 to service clients, handing out IP addresses in the 192.168.111.0/.24 subnet.... so the client gets an IP address, for example 192.168.111.123, which is on the GuestWireless SSID which is assigned to VLAN 11. So far I am hung up on the DHCP part, which I thought would be the easiest part- the device I am testing with just keeps not getting a DHCP address- it gets an APIPA and reports no internet (It's an iPhone). How do I fix things so first, DHCP works, and second so the SSID sends traffic out that is isolated from the production network? I am planning to eventually use web authentication with a captive portal. Pie-in-the-sky would be guest self-registration, but I am focusing on just getting the device connected to the SSID, and traffic properly flowing to the Internet. I appreciate any help.
Thanks!
Sandeep Choudhary
Go through the document:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
Dont forget to rate helpful posts
Thanks for the link!
I went through the article, and the first problem I am having is on the guest network- I need the wireless client to obtain its IP from the WLC. Right now, it never gets the IP- it ends up with something in the 169.254.0.0/16 space. The link does not have the internal DHCP config, which is what I need to get started... any additional resources that might be helpful here? Also, I am using 8.5.140..... should I be using a newer software version on the WLC/WAP's?
Here is a dump of the dhcp debug on the WLC for this client:
(Cisco Controller) >debug client 78:88:6d:2d:96:ab
(Cisco Controller) >*IPv6_Msg_Task: Aug 28 11:19:29.204: 78:88:6d:2d:96:ab Link                                                          Local address fe80::c40:9cb3:3646:9f2 updated to mscb. Not Advancing pem state.C                                                         urrent state: mscb in apfMsMmInitial mobility state and client state APF_MS_STAT                                                         E_ASS
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP received op BOOTR                                                         EQUEST (1) (len 308,vlan 0, port 1, encap 0xec03, xid 0x210833cb)
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP (encap type 0xec0                                                         3) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP selecting relay 1                                                          - control block settings:
                        dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
                        dhcpGateway: 0.0.0.0, dhcpRelay: 192.168.111.2  VLAN: 11
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP selected relay 1                                                          - 192.168.1.68 (local address 192.168.111.2, gateway 192.168.111.1, VLAN 11, por                                                         t 3)
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP selecting relay 2                                                          - control block settings:
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP selected relay 2                                                          - NONE (server address 0.0.0.0,local address 192.168.111.2, gateway 192.168.111.                                                         1, VLAN 11, port 3)
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP transmitting DHCP                                                          DISCOVER (1)
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP   op: BOOTREQUEST                                                         , htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP   xid: 0x210833cb                                                          (554185675), secs: 59, flags: 0
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP   chaddr: 78:88:6                                                         d:2d:96:ab
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP   ciaddr: 0.0.0.0                                                         ,  yiaddr: 0.0.0.0
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP   siaddr: 0.0.0.0                                                         ,  giaddr: 192.168.111.2
*DHCP Socket Task: Aug 28 11:19:29.831: 78:88:6d:2d:96:ab DHCP sending REQUEST t                                                         o 192.168.111.1 (len 374, port 3, vlan 11)
*apfOpenDtlSocket: Aug 28 11:19:32.849: 78:88:6d:2d:96:ab Received management fr                                                         ame DISASSOC            on BSSID c4:b3:6a:a4:db:ac destination addr c4:b3:6a:a4:                                                         db:ac
*apfMsConnTask_2: Aug 28 11:19:32.849: 78:88:6d:2d:96:ab Got disassoc frame from                                                          78:88:6D:2D:96:AB BSSID= C4:B3:6A:A4:DB:A0  reasoncode = 8 dataLen = 14
*apfMsConnTask_2: Aug 28 11:19:32.849: 78:88:6d:2d:96:ab Apple_IE: Subtype = 2 V                                                         ersion = 1 Reason = 8, Subreason = 0
*apfMsConnTask_2: Aug 28 11:19:32.849: 78:88:6d:2d:96:ab MS Associated AP c4:b3:                                                         6a:a4:db:a0 slot 1 MFP Disabled , 11w Disabled
*apfMsConnTask_2: Aug 28 11:19:32.849: 78:88:6d:2d:96:ab Ignoring received Disso                                                         c frame on AP c4:b3:6a:a4:db:a0 slot 1
*apfOpenDtlSocket: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Received management fr                                                         ame ASSOCIATION REQUEST  on BSSID c4:b3:6a:a4:a6:43 destination addr c4:b3:6a:a4                                                         :a6:43
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Updating 11r vendor IE
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Processing assoc-req st                                                         ation:78:88:6d:2d:96:ab AP:c4:b3:6a:a4:a6:40-00 ssid : Visitors thread:1e0e97a0
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Station:  78:88:6D:2D:9                                                         6:AB  trying to join WLAN with RSSI -28. Checking for XOR roam conditions on AP:                                                           C4:B3:6A:A4:A6:40  Slot: 0
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Station:  78:88:6D:2D:9                                                         6:AB  is associating to AP  C4:B3:6A:A4:A6:40  which is not XOR roam capable
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Client AVC Roaming cont                                                         ext transfer needed? NO
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Setting RTTS enabled to                                                          0
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Association received fr                                                         om mobile on BSSID c4:b3:6a:a4:a6:4c AP USMDWAP01
*apfMsConnTask_7: Aug 28 11:19:39.412: 78:88:6d:2d:96:ab Global 200 Clients are                                                          allowed to AP radio
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Max Client Trap Thresho                                                         ld: 0  cur: 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Rf profile 600 Clients                                                          are allowed to AP wlan
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab override for default ap                                                          group, marking intgrp NULL
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Applying Interface(gues                                                         t) policy on Mobile, role Local. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 11
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Re-applying interface p                                                         olicy for client
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Changi                                                         ng IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.                                                         c:3091)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Changi                                                         ng Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --                                                         - (caller apf_policy.c:3111)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Changi                                                         ng IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.                                                         c:3132)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Values before applying                                                          NASID - interfacetype:3, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab apfApplyWlanPolicy: App                                                         ly WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Check before Setting th                                                         e NAS Id to WLAN specific Id ''
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Check the client SGT 0                                                          policy and push it to AP c4:b3:6a:a4:a6:40
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab In processSsidIE:6903 s                                                         etting Central switched to TRUE
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab In processSsidIE:6906 a                                                         pVapId = 4 and Split Acl Id = 65535
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Applying site-specific                                                          Local Bridging override for station 78:88:6d:2d:96:ab - vapId 4, site 'default-g                                                         roup', interface 'guest'
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Applying Local Bridging                                                          Interface Policy for station 78:88:6d:2d:96:ab - vlan 11, interface id 10, inte                                                         rface 'guest', nasId:''
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab processSsidIE  statusCo                                                         de is 0 and status is 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab processSsidIE  ssid_don                                                         e_flag is 0 finish_flag is 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab STA - rates (8): 130 13                                                         2 139 150 36 48 72 108 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab suppRates  statusCode i                                                         s 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab STA - rates (12): 130 1                                                         32 139 150 36 48 72 108 12 18 24 96 0 0 0 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab extSuppRates  statusCod                                                         e is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab pemApfDeleteMobileStati                                                         on2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab the value of url acl pr                                                         eserve flag is 1 for mobile 78:88:6d:2d:96:ab (caller pem_api.c:4922)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Delete                                                         d mobile LWAPP rule on AP [c4:b3:6a:a4:db:a0]
*pemReceiveTask: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 Removed NPU entr                                                         y.
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Succesfully freed AID 1                                                         , slot 1 on AP c4:b3:6a:a4:db:a0, #client on this slot 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab New ctxOwnerMwarIp:  19                                                         2.168.3.68 New ctxOwnerApMac:  C4:B3:6A:A4:A6:40 New ctxOwnerApEthMac:  C4:B3:6A                                                         :A4:20:88 New ctxOwnerApSlotId: 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Updated location for st                                                         ation old AP c4:b3:6a:a4:db:a0 oldSlot 1, new AP c4:b3:6a:a4:a6:40 newSlot 0, AI                                                         D 0 MsType 0 MobilityRole 1
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Assigning flex webauth                                                          ACL ID :65535 for vlan : 4
*spamApTask7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Setting DEL_MOBILE (seqno 0                                                         , action 6) ack state for STA on AP c4:b3:6a:a4:db:a0
*spamApTask7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Delete Mobile request on sl                                                         ot 1 sent to the AP c4:b3:6a:a4:db:a0 IP: 192.168.3.88:5248
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Allocate AID 1 slot 0 o                                                         n AP USMDWAP01 #clients on this slot 1
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Applie                                                         d RADIUS override policy
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Adding                                                          Fast Path rule
  type = Airespace AP Client
  on AP c4:b3:6a:a4:a6:40, slot 0, interface = 1, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID = 255, L
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Fast P                                                         ath rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 64206, IntfId = 10  Local Br                                                         idging Vlan = 11, Local Bridging intf id = 10
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Fast P                                                         ath rule (contd...) AVC Ratelimit:  AppID = 0 ,AppAction = 0, AppToken = 64206                                                           AverageRate = 0, BurstRate = 0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Succes                                                         sfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255, L2 ACL ID 255,URL                                                          ACL ID 255,URL ACL Action 0)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Not Using WMM Complianc                                                         e code qosCap 00
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab flex webauth acl id to                                                          be sent when fabric is disabled:65535
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab flex webauth acl id to                                                          be sent :65535 name : client acl id : 65535
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Vlan while overriding t                                                         he policy = -1
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab sending to spamAddMobil                                                         e vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Plumbe                                                         d mobile LWAPP rule on AP c4:b3:6a:a4:a6:40 vapId 4 apVapId 4 flex-acl-name:
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab 0.0.0.0 RUN (20) Change                                                          state to RUN (20) last state RUN (20)
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab spamSendFabricClientReg                                                         istration: Not sending Registration for Fabric client 78:88:6d:2d:96:ab, primary                                                          and secondary MS IP is zero
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab apfPemAddUser2 (apf_pol                                                         icy.c:423) Changing state for mobile 78:88:6d:2d:96:ab on AP c4:b3:6a:a4:a6:40 f                                                         rom Associated to Associated
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab apfPemAddUser2:session                                                          timeout forstation 78:88:6d:2d:96:ab - Session Tout 1800, apfMsTimeOut '1800' an                                                         d sessionTimerRunning flag is  0
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Scheduling deletion of                                                          Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Func: apfPemAddUser2, M                                                         s Timeout = 1800, Session Timeout = 1800
*apfMsConnTask_7: Aug 28 11:19:39.413: 78:88:6d:2d:96:ab Sending assoc-resp with                                                          status 0 station:78:88:6d:2d:96:ab AP:c4:b3:6a:a4:a6:40-00 on apVapId 4
*apfMsConnTask_7: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab Sending Assoc Response                                                          (status: '0') to station on AP USMDWAP01 on BSSID c4:b3:6a:a4:a6:43 ApVapId 4 Sl                                                         ot 0, mobility role 1
*apfMsConnTask_7: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab apfProcessAssocReq (apf                                                         _80211.c:11962) Changing state for mobile 78:88:6d:2d:96:ab on AP c4:b3:6a:a4:a6                                                         :40 from Associated to Associated
*pemReceiveTask: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab 0.0.0.0 Added NPU entry                                                          of type 1, dtlFlags 0x0
*spamApTask1: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab Add SGT:0 to AP c4:b3:6a:a4                                                         :a6:40
*spamApTask1: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab Add CTS mobile SGT - Encode                                                         d the capwap payload for the mobile with SGT 0
*pemReceiveTask: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab Pushing IPv6: fe80:0000:                                                         0000:0000:0c40:9cb3:3646:09f2 , intfId:10 and MAC: 78:88:6D:2D:96:AB , Binding t                                                         o Data Plane. SUCCESS !!
*spamApTask1: Aug 28 11:19:39.414: 78:88:6d:2d:96:ab Successful transmission of                                                          LWAPP Add-Mobile to AP c4:b3:6a:a4:a6:40
*spamApTask7: Aug 28 11:19:39.416: 78:88:6d:2d:96:ab apfUpdateDeleteAckInMscb (a                                                         pf_api.c:54210) Expiring Mobile!
*apfOpenDtlSocket: Aug 28 11:19:39.419: 78:88:6d:2d:96:ab Received management fr                                                         ame ACTION              on BSSID c4:b3:6a:a4:a6:43 destination addr c4:b3:6a:a4:                                                         a6:43
*apfMsConnTask_7: Aug 28 11:19:39.419: 78:88:6d:2d:96:ab Received management act                                                         ion frame (category code:5) from the client.
*apfMsConnTask_7: Aug 28 11:19:39.419: 78:88:6d:2d:96:ab Found RM action categor                                                         y code
*apfMsConnTask_7: Aug 28 11:19:39.419: 78:88:6d:2d:96:ab Station:  78:88:6D:2D:9                                                         6:AB  sent 802.11K neighbor request to AP  C4:B3:6A:A4:A6:40
*apfMsConnTask_7: Aug 28 11:19:39.419: 78:88:6d:2d:96:ab Station:  78:88:6D:2D:9                                                         6:AB  requested neighbors on non XOR roam capable AP  C4:B3:6A:A4:A6:40  Slot 0
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP received op BOOTR                                                         EQUEST (1) (len 308,vlan 0, port 1, encap 0xec03, xid 0x210833cc)
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP (encap type 0xec0                                                         3) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP selecting relay 1                                                          - control block settings:
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP selected relay 1                                                          - 192.168.1.68 (local address 192.168.111.2, gateway 192.168.111.1, VLAN 11, por                                                         t 3)
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP selecting relay 2                                                          - control block settings:
*DHCP Socket Task: Aug 28 11:19:39.491: 78:88:6d:2d:96:ab DHCP selected relay 2                                                          - NONE (server address 0.0.0.0,local address 192.168.111.2, gateway 192.168.111.                                                         1, VLAN 11, port 3)
It's recommended to use 8.5.151.0 at this time. If you upgrade the WLC, the APs will automatically also be upgraded.
For internal DHCP server, check: https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/dhcp.html#d61685e2519a1635
Please note, you have bought an enterprise product, with many enterprise features. It has a fairly steep learning curve, if you are setting it up for the first time.
Also, if you can, I suggest you use a third party guest portal, they offer way more features than what the WLC has built-in.
