12-14-2011 07:46 AM - edited 07-03-2021 09:14 PM
In the WLC there are two groups (say A and B). How would I take group B and point it to a RADIUS server for authentication please? Looking for a step by step answe please. The server is ping reachable. I have seached but did not see any difinitive answer.
Thanks!
12-14-2011 08:05 AM
I should add that the RADIUS box's IP is in the WLC. I guess I'm just looking for how to make group "B" go through the RADIUS server for authentication please.
12-14-2011 09:53 AM
at the moment, the only way to do this is on a per SSID basis if you really want seperation.
now, that being said, If user B does not exist in the domain of AAA -A, then it will not respond, or at least not with a reject. After the third attempt, the WLC should send the request to AAA-B.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
08-27-2012 12:05 AM
You can achieve what you want per WLAN.
configure authentication servers order in wlan settings as per this image:
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
