Help please
george
Level 2
Level 2
i have LWAP 1242
the problem is when i type config t it shows me an error of typing and i can't go on
could you help me please
Surendra BG
Hi George,
U need t oconvert the image on the AP to Autonomous.. here is the doc written by me and this will help u out in getting the issue resolved!!
https://supportforums.cisco.com/docs/DOC-14960
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Hello Surendra
first of all thank you for your reply
why i have to convert my image to autonomous ?
this is the only solution for my problem ? if so when i checked the steps, i saw that i have to type config t and as i
explain for you i can't type config t
thank you
regards
Yes u need to re image to Autonomous.. To convert please issue the hidden debug command and then convert.. please follow the exact steps.. i guess ur missing the main command..
AP>en
AP#debug lwapp console cli or debug capwap console cli
after this command u will be able to go into the conf t and then convert the image using the next following steps..
Follow the instructions!! and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
thank you a lot
i will try it
