Help replacing old Anchor controller
derek.small
Level 3
Level 3
I have a customer with an old 5508 Anchor controller which is used by a number of primary controllers.  I built a new 5520 anchor controller but am trying to test it by bringing up a new mobility group on one of the primary controllers, that I plan to map a single AP, and test SSID to using a new AP group.  However I cannot get the mobility group up from the primary controller to the new anchor.  The data path is up, but the Control Path is Down.  Is it because the old anchor and the new anchor are both trying to use UDP 11666?  If so, is there a way to change the port the new anchor is trying to use for the tunnel?  There are no firewalls or other traffic filtering devices (ACLs) between the new anchor and the primary controller I'm trying to test with.
5 Replies 5
Mark Elsen
 - I would start with a checkup of the 5520 configuration using : WirelessAnalyzer input (procedure) for AireOs controllers
   have the output analyzed with Wireless Config Analyzer
  Also look into software versions on all  involved controllers ; if possible and where needed take care according to :
              https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
                                 especially if there are older versions being used somewhere ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
derek.small
Level 3
Level 3
I will give that a shot.  I did just notice something that might be the problem.  The MAC that is being reported on the new Anchor for the local mobility group does not match the burned in MAC for the new Anchor WLC.  You can't change that in the config so I don't know how that got set to something different than the MAC on the WLC.  Any ideas?
 - This info does not relate to your problem (exactly) , but check if it can lead to hints :
                             https://www.examtopics.com/discussions/cisco/view/98075-exam-300-425-topic-1-question-87-discussion/
  M.
Mark Elsen
 - FYI (added) : https://community.cisco.com/t5/wireless/cisco-5508-anchor-controller-2504-primary/m-p/3690465#M207329
 M.
Rich R
What versions of software are the controllers running?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
