Help with basic Wi-Fi Configuration (3850 + 3602I LWAP)
Ozan1
Hi all,
I have a 3850 in which I've downgraded the code to get the wireless controller commands. I need help with configuring it to broadcast an SSID with basic WPA2 PSK configuration and extend a data vlan from the switch to clients.
I ran into this website, hoping that it would be relavant, however I am stuck with the AP NAME. The switch cannot find the AP name.
Any help or guidance is much appreciate. Thank you.
EDIT* I just realized there is a prep page before Part 1 -
https://mrncciew.com/2013/09/29/getting-started-with-3850/
3850-1#ap name L3502-1 ap-groupname 3850
https://mrncciew.com/2013/12/04/wlan-config-in-3850-part-1/
balaji.bandi
that URL you provided very useful, you still have issue is this resolved ?
BB
Thank you. I have an issue assigning a VLAN to the management interface. The WLC (3850 switch) does not see the AP registering. I made sure time and time zone are correct. I believe it is the VLAN. On the SW, I have assigned VLAN 200 as the management VLAN. Vlan200 is also where I have DHCP configured.
If I set the port connecting to the AP as access port 200, the AP picks up an IP address and I can access the web GUI. However, the switch doesn't see it register.
wireless management interface Vlan200
SW Config
Interface G1/0/2
switchport mode trunk
3850-SW#show ap summary
Number of APs: 0
Global AP User Name: Not configured
Global AP Dot1x User Name: Not configured
ap#show run
Building configuration...
Current configuration : 1596 bytes
! Last configuration change at 15:07:47 UTC Wed Sep 7 2022
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$uSlJ$BwMxqJTkexNIzaImXc/c70
no aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
no ipv6 cef
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
peakdetect
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address c464.13b4.4699
ip address dhcp
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
