Help with WLC 5508 configuration
James060277
Hello all, first off let me start by saying I am very new to this so I apologize ahead of time but am very eager to learn. I have a WLC 5508 and a Catalyst 2960S as well as 3 AIRCAP 3502E access points. I have read books and watched tons of Youtube videos but I still cant get my access points to find the WLC. I am finally done beating my head against a wall and am hoping someone can help.
15 Replies 15
That's a bad IP address for the management GUI, I suggest to rather use 192.168.2.2 or higher. Reserve the x.1 addresses for your 2821 or ASA, depending on which device is routing the VLAN in which the IP range 192.168.2.x/xx configured.
So first things first, create 2 VLANs for the wireless, one for management (where the APs and WLC ap-manager interface will be connected to) and one for the clients. The WLC then requires a Trunk port from your switch (assuming you have a manageable switch) or router, containing both VLANs.
Assume 192.168.2.0/24 is VLAN 20 (client access) and 192.168.1.0/24 is VLAN 10 (management). In the initial setup of the WLC, or later the interface configuration, you have to tag those two interfaces with the correct VLAN number.
On the router you create two vlans and then vlan interfaces:
conf t
vlan 10
name management
vlan 20
name clients
int vlan 10
no shut
int vlan 20
ip address 192.168.2.1 255.255.255.0
no shut
By entereing those commands you have created routing on the router for the two networks and also the required vlans. Leave the ASA away for the start. You will also somewhere require NAT (for internet access), but for just testing try to attach a wired client to vlan 20 and ping it.
The APs you add to a switch which is configured for Access Port Vlan 10 (management), the wired test client to Access Port Vlan 20. The Switch and Router must be connected by a Trunk port. You can leave the Switch away if you have enough Ports on the router.
