How do I enable 802.11k on Cisco 5508 running 8.0.120.0
Bryce Stewart
I just upgraded a 5508 WLC to 8.0.120.0 and I have clients that are starting to have issues roaming from AP to AP using Apple / MAC devices.  How do I check to see if 802.11k is enabled on the controller and what would be the best practices to implement the protocol to help users.
Things I think I know.....
I understand this is a protocol that is enabled globally per WLAN
You can only enable and disable this in CLI on most software versions.
Things I need to know.....
Do you have to enable the assisted roaming floor-bias too?
Do you have to enable the dual-band list as well?
-Bryce
Rasika Nayanajith
Here is the current best practice for AireOS controller. Enabling 802.11k is one of them as well.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/wlc/82463-wlc-config-best-practice.html#pgfId-380513
Rasika
*** Pls rate all useful responses ***
Hello Rasika,
I would like to ask you for a specific question. It is better to use client load balancing or use Assisted roaming Prediction Optimization? Both cannot be enabled together.
Thank you
O_A_H
Listed below are the recommended WLC configuration commands for 802.11k using CLI. There is no GUI config for 802.11k:
  • WLAN neighbor list Enable/Disable: This is to enable or disable the neighbor list from the WLC and also the RRM and Power Constraint Information Elements (IEs) on the APs.
config wlan assisted-roaming neighbor-list {enable|disable} wlanId
  • WLAN neighbor list dual-band response Enable/Disable: This is to enable or disable the neighbor list including entries for both radio bands. Default is the band in which the client is currently associating.
config wlan assisted-roaming dual-list {enable|disable} wlanId
  • Prediction list based assisted roaming Enable/Disable: This is to enable or disable the assisted roaming capabilities with a roaming optimization predict list. A warning will be printed out, and load-balancing will be disabled for the WLAN if load balancing is already enabled on the same WLAN.
config wlan assisted-roaming prediction {enable|disable} wlanId
You can find the list of Apple devices best practices in the the following document:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/vowlan/bestpractices/EntBP-AppMobDevs-on-Wlans.pdf
*** Thanks to rate the useful response :) ***
