How do you factory default the MSE 3350 Mobility Solution Engine
krishanmistry
Hi Guys
I was wondering if anyone knows how to factory default the MSE or know of a way to enable the setup wizard again.
Is there a way to check the status or change the WCS communication password manually.
Thanks in advanced
bbxie
Level 3
Level 3
You can use following steps to restore factory default fo MSE:
Step 1 In Cisco WCS, click Mobility > Mobility Service Engines.
Step 2 Click the name of the mobility services engine you want to configure.
Step 3 Click System (left panel).
Step 4 Click Advanced Parameters.
Step 5 In the Advanced Commands section (right), click Clear Configuration.
Step 6Click OK to clear the mobility services engine configurations.
You can also run this from the cli to get the startup wizard:
/opt/locserver/setup/setup.sh
-Scott
