How much radiation produced by AIR-AP3802I-H-K9?
Watuji Hoe
Hi Guys,
Have queries from client regarding the radiation level produced by AP AIR-AP3802I-H-K9 from a height of 3 meters.
Tried to find in few data sheets, doesn't specifically show the readings.
Flexible radio (either 2.4 GHz or 5 GHz
  2.4 GHz, gain 4 dBi, internal antenna, omnidirectional in azimuth
  5 GHz, gain 6 dBi, internal directional antenna, elevation plane beamwidth 90°
Dedicated 5-GHz radio
  5 GHz, gain 5 dBi, internal antenna, omnidirectional in azimuth
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1200-access-point/prod_white_paper09186a0080088791.html
In this link, there's a writing :
"In most circumstances, low-power radios (such as WLANs) operating at less then 100mW Effective Isotropic Radiated Power (EIRP) and operating at 2.4 and 5.8 GHz should not pose any risk if operated under normal circumstances. However, it is recommended that you first consult the facility’s safety administration to determine its policy on the use of RF devices in certain areas. "
Does this also applies to 3800 series AP?
J.
patoberli
Yes, it's the same for all models. Please note, different country regulations give different maximum power settings. Not sure what it is for the -H- model.
