How to adjust tx power of APs in 9800?
Rasika Nayanajith
If you need an individual AP level, you can go to "Configuration -> Wireless -> Access Point > {2.4|5.0GHz}". See below
If you need WLC to decide globally you can let RRM do it (Configuration -> Radio Configuration -> RRM -> TPC)
Rasika
*** Pls rate all useful responses ***
5 Replies 5
you can use RRM in WLC
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/radio-resource-management.html#ID76
Good luck
KB
Rasika Nayanajith
Rasika
pronko8901
hi,please help ,i cant see m to find Role assignment?
Gaurav  Kansal
Dear Snika,
You can adjust power of access point from Configuration>Wireless>Access points> 5Ghz or 2.4Ghz access point configuration page. You can change it from global setting to custom.
Note: It is recommended to leave this power assignment as global and let WLC do its job.
Hi thank you so much, this worked
