How to change dual 5GHz mode to 2.4 & 5 GHz mode for AP3800 ?
HI everyone ,
I know the AP3800 support dual 5GHz mode,but we want to use 2.4G & 5G mode.I don't know how to check and change it .Could you please tell me how to change dual 5GHz mode to 2.4 & 5GHz mode?
Thanks a lot !
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
10 Replies 10
Leo Laohoo
Disable Flexible Radio Assignment (FRA).
HI Leo
Thanks for your response.
Yes, i think so,but where i can disable the FRA ? I didn't find it in GUI.
Could you tell me how to disable it or is there any documents for this issue ?
Thanks & BR
Wireless > Advanced > RF Management > Flexible Radio Assignment
It is as below:
Wireless > Advanced > RF Managment > Flexible Radio Assignment ,the choose the "disable"
dual 5GHz will be disabled after disable FRA ? Is there any can check i have use the 2.4G&5GHz,not the dual 5GHz?
-hope this helps-
aogston
Hi.  You can do this manually on the WLC itself.
Try
config slot 0 disable "AP-Name-Here"
config 802.11-abgn role "AP-Name-Here" manual client-serving
config 802.11-abgn band ap "AP-Name-Here" 2.4GHz
config slot 0 enable "AP-Name-Here"
Andy.
Where i can find this in GUI ?
I do believe that once you follow Leo's guidance: Wireless > Advanced > RF Management > Flexible Radio Assignment
and select Disable, Since this is a Global command, the AP radios that are in the 5g mode will reset back to 2g.
In the auto mode the wlc only moves the radio from 2g to 5g if there is plenty of 2g coverage
also Wireless/Access Points/Radios/Dual-band Radios
will present you your list of 2800/3800 dual band modules..
mouse over to the blue down arrow and select ..  configure.
Radio role Assignment
typically Auto...  make it Manual/Client serving and band 2.4G.
HI David,
Thanks for your reply.
