How to Classify AdHoc Rogues?
jnlawrence76
I have been able to manually classify the Unclassified APs that I find, however I have not been able to find out a way to manually classify Adhoc Rogues.  Can anyone point me in the right direction?  Do I have to creat a rule in order to classify Adhoc Rogues?
Thanks in Advance
WLC - 7.0.98.0
WCS - 6.0.170.0
Go to WCS Home > Security Tab > Total Active Adhoc Rogues > under Adhoc Rogue Alarms put a "tick" on the Adhoc Rogues of your choice > on the upper left-hand corner there's a drop-down box > choose "External".
Hope this helps.  Please don't forget to rate our useful posts.  Thanks.
5 Replies 5
Leo Laohoo
On the WLC:
Rogues > Adhoc Rogues > MAC Address > Contain
If I set them to "Contain" will this cause a problem for the AdHoc devices?
Nuts.
You can aside from "Contain", you can choose some more options:   Contain, Alert, Internal, External
When you contain, you are literally sending successive de-authenticate packet to the client.  This is similar to doing a DDoS.
What about setting a rule to set adhocs to "External"?  I have about 500 showing up right now and manually changing each one would take some time.  I only seem to see the ability to create rules for Rogue APs
