04-03-2021 04:03 AM - edited 07-05-2021 01:05 PM
I am newbie too Cisco device
I want clients roaming to new AP when RSSI lower than -70dbi
Can I do it on this menu
and Minimum RSSI value is when clients get lower RSSI will roaming to others AP right ?
Thanks for your comment
04-03-2021 05:01 AM
Wireless clients decide when to roam and which AP to go to.
For Intel-based wireless NIC, the easiest way is to update the firmware of the wireless NIC.
Andoid-based wireless client will require an app, like WiFi Roaming Fix.
04-04-2021 03:24 AM
04-06-2021 08:43 AM
As Leo already stated, the client decides by itself when/if it wants to roam. This is defined by the manufacturer inside the driver.
You can influence this, but this can cause outages and "no network" issues for the client. Those features are Client Load Balance and Band Select.
I advice against using those features, because they typically cause more issues than they solve it.
