Bookmark
Subscribe
1430
upgrade wlc 2504 7.2 to 8.2
Seckerfers
greetings,
We are planning to upgrade our AP into 2800 series ( currently running 1140 series), as per i read on compatibility matrix cisco for 2800 are supported on 8.2.x OS and currently our wlc running an Old OS 7.2.103...should it be upgraded to 7.4/7.6 and then to 8.2 or could be upgrade directly? and would it be impacting to our existing license if i'm upgrading to 8.2? and should i need upgrade the FUS as well?
Thanks a lot for any help.
2 Accepted Solutions
 - As far as required FUS version is required check Table 4 of this document :
          https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr7.html
 M.
@Seckerfers wrote:
Big thanks for your reply, should i upgrade FUS first ?? or just upgrade the OS and then FUS?
Upgrade the FUS, reboot.
Upgrade the OS, reboot.
@Seckerfers wrote:
is it still possible to upgrade directly to 8.3.x from 7.2.x??
It is possible to upgrade direct from 7.2.X.X to 8.2.X.X.
It is NOT possible to upgrade direct from 7.2.X.X to 8.3.X.X without going to 8.2.14X.X first.
8 Replies 8
Leo Laohoo
You can go direct to 8.2.X.X.
Hi Leo,
and once more...is it still possible to upgrade directly to 8.3.x from 7.2.x??
Well noted then, thanks a lot for your help
marce1000
                  - What is the wlc-model ?
 M.
Hi Marce,
Thanks for your reply, currently i'm using 2504. Is it possible or any issue with that model?
 M.
understood, thanks a lot for your help
