How to configure android device WIFI roaming
hook huang
I have configured WIFI SSID for mobility device to connect network. (ex:iphone,android phone, pad etc...)
And we use notebook connect to SSID, and check WIFI roaming status, it always only one maybe two times by Ping.
But when we try to user Android PAD to connect SSID, when it roam from AP1 to  AP2,
The android PAD will lost WIFI connection about 5~8 second.
Is this normal status, or android device need to configure something ?
Wireless device:
WiSM2(8.0.110), AP1702I
Android device type:
 --samsung galaxy S--
 --iPad mini--
By Hook~~~
Scott Fella
That is not normal especially of the APs are in the same WiSM2.  You might want to review how your wlan is configured. Try not to have multiple encryption types. Use WPA2/AES only if possible not WPA2/AES and WPA/TKIP together.
-Scott
-Scott
Hi, Scott
I have change the SSID confuration.
The SSID have only one encryption type ,WPA2/AES.
But it still have some problem.
By Hook~~~
Saurav Lodh
Level 7
Level 7
Encryption does consume the resources hence delay however hardware could also be a reason. Found one discussion where diff. android models have issue with roaming
https://code.google.com/p/android/issues/detail?id=12649
