Compatible Versions of WCS,WLC, and MSE
reilly.john
Trying to determine if I have any compatibility issues between my wireless WCS MSE and WLC'c
WCS version 7.0.230.0  feature plus
WLS version 7.6.130.0 in an HA configuration
MSE version 7.0.220.0
I just recently upgraded my WLC 5508's to an HA configuration and added 200 AP Lic to the WCS.
I am looking to upgrade my WCS to Cisco Prime Infrastructure just for my wireless network devices and am wondering if my AP lisc count from the WCS will transfer to Cisco Prime Infrastructure and to make sure my other devices are still okay or need an upgrade.
I have looked at all the literature I can find and cannot seem to find a definitive answer.
John
Hi John,
Here is the Prime,WLC,MSE compatibility matrix
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148422
Regarding the licence (WCS-Prime) you have to get migrated licences from Cisco & once you build new prime, you can installed those licenses.
I would advise you to go to PI 2.2 straight when moving.
Rasika
**** Pls rate all useful responses ****
Hi John,
Rasika
