12-10-2013 11:35 AM - edited 07-04-2021 01:24 AM
In our project already one controller and 90 access points are configured but client want to install stand by WLC.
what configuration is to done on both Active wlc and stand by wlc.
12-10-2013 11:49 AM
it depends on what you have license and code wise.
If you are running 7.4 and your new WLC is 50 licenses or the HA-SKU you coudl configure AP-SSO
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
If you are not wanting to go that route, then you need to configure the new WLC exactly the same as the original, with the exception of the IP addresses on each dynamic interface.
Then you add them to the same mobility group.
the difference is, with AP-SSO, it is a true master/slave db. You change the master and it gets pushed to the slave.
otherwise, if you make changes to one, you need to make changes to the other as well.
Cisco PI, can help with that by allowing you to push templates to each WLC.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-11-2013 03:35 AM
Thanks for your reply.both controller supports licences already actvie one is configured just how to configure standby
what configuration we have done on both controller. and one access point want to firmware upgrade .how to upgrade
12-11-2013 03:45 AM
HI Sayed,
Which version of code u r running on WLC ??
12-12-2013 01:29 AM
Thanks for your reply the code version 7.3
12-12-2013 02:44 AM
HI Syed,
If you are running 7.3 version then .
I dont know in whcih manner u r saying standby:
is it a normal secondary controller or ?
r u using HA(AP SSO) or ?
If its normal as secondary controller then please visit this:
This is already menstion by Scott.
If you are using HA-AP SSO then please visit this:
Dont forget to rate helpful posts.
12-12-2013 11:35 AM
Thanks for your reply.this is information i got from my team i am beginner in wireless please advice yhe solution
already one controller is running with code version 7.3 with active controller now they standy by controller for redunacy
please advice.
12-11-2013 03:50 AM
Check the release notes for the code you want to upgrade to. The release notes will tell you how to upgrade to that code from the code you are on.
http://www.cisco.com/en/US/products/ps10315/prod_release_notes_list.html
Here is a compatibility matrix to help you know what code is compatible with what.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Here is a doc on how to configure access point high availability since you have two wlc's with licenses.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml
