How to deny an AP Access for AP Users ?
aessome
Hello Guys,
i configure Portocol filter like on this Page , but still get a connection to my AP when i connect as a user,
please help
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a00800e02cf.html#1028373
derwin
Level 5
Level 5
Hi not sure 100% what you are trying to ask given the information you provided.
If you want to stop un authorized client cards associating via the MAC address then the filtres you need to set up are described here
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch8.htm#1029067
If ypu are simply trying to filter out certain types of traffic then the link you showed is the correct one can please describe exactly want you want to acheive
i do some filtering.
My wireless clients were unable to conenct to the network,fine.But under the log the A.P still associating my wireless PC card?
please make sure that the AP is configured for this exactly as per the docco
one of the common mistakes is the setting "is mac authentication alone sufficent to fully authenticate" should be set to no unless you are doing BOTH server based MAC and EAP
Also make sure you are using the latest firmware or after you have configured it and applied then reload the AP
