Wireless VLAN setup with 802.1x clients
ctinajero
Hello there,
All my WAPs are running Cisco 350 Series AP 12.02T1. I set up a couple of VLANs (one for the users and the other one for the WAPs). All my Cisco Aironet clients worked fine; however, my 802.1x clients could not associate.
I need specific steps on how to set up my WAPs with VLANs to service Cisco Aironet clients as well as 802.1x.
Any help would be greatly appreciated.
Carlos T.
CCNA
derwin
Level 5
Level 5
ensure your vlans are correctly set up as per this link
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch4.htm
Then within the vlan you want eap make sure it is configured as per
Then if it is still not working use the EAP diag found here to see if the problem is the client the ACS or AP
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap35ch13.htm#1044224
