how to enable HTTPS on a wlc-2100
axfalk
Level 7
Level 7
Can someone please let me know the command to enable the HTTPS on a wlc from cli?
thanks..
Rob Huffman
Hi Greg,
Here is the method;
Using the CLI, follow these steps to enable HTTPS:
Step 1 Enter show certificate summary to verify that the controller has generated a certificate:
Web Administration Certificate................. Locally Generated
Web Authentication Certificate................. Locally Generated
Certificate compatibility mode:................ off
Step 2 (Optional) If you need to generate a new certificate, enter this command:
>config certificate generate webadmin
After a few seconds the controller verifies that the certificate is generated:
Web Administration certificate has been generated
Step 3 Enter this command to enable HTTPS:
>config network secureweb enable
Step 4 Save the SSL certificate, key, and secure web password to NVRAM (non-volatile RAM) so your changes are retained across reboots:
>save config
Are you sure you want to save? (y/n) y
Configuration Saved!
Step 5 Reboot the controller:
>reset system
Are you sure you would like to reset the system? (y/n) y
System will now restart!
The controller reboots.
From this good doc;
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40intf.html#wp1115958
Hope this helps!
Rob
