How to flash firmware from uboot? Model C9105AXI-D
arun321
The device does not complete the boot process. It hangs after autoboot and shows CPU reset.
Only uboot menu is working fine. Is there any way to flash firmware from uboot? It seems both partitions are corrupted.
Thanks.
7 Replies 7
The download page also include 9105 images @Flavio Miranda
So yes, you can use that process to re-flash the 9105 from u-boot.
Note that restores the AP to 8.10.130.0 image so I usually recommend upgrading:
8.10.130.0 -> 8.10.196.0 (15.3.3-JK11) then
8.10.196.0 -> 17.6.8 (15.3.3-JPK9) then
17.6.8 -> current version like 17.15.2 (15.3.3-JPT1)
Trying to upgrade direct from 8.10.130.0 to latest usually results in failure.
arun321
Official documentation is lacking some important steps. Anyhow, I fixed it with help from other posts.
It's worked fine for me when I've used it before @arun321 but if you think there's something missing you should share the details here for others, and submit feedback on the article detailing what you think needs updating.
hello @arun321 how did you fix it am experiencing the same problem please share the solution link ,i hav eabout 5 AP with this problem
Did you follow the process at https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html @adocriss99 ?
