how to identify "CT5508-HA Unit "
Andrey128
how can I identify that a certain wireless controller is "CT5508-HA Unit "?
That is correct. You need 50 ap license to make a non-ha wlc as an HA.
-Scott
5 Replies 5
Scott Fella
For the 5508, you need to look at the box. You can reference the order also to see what SN is tied to the HA controller.
-Scott
unfortunately I cannot check the order documents, SN looks normal, cannot recognize if it is HA unit or not:
FCW1546L03Z
AIR-CT5508-K9
Well one unit would be able to have license installed and the other will not. Have you checked to see if one has licenses already? These are new out of the box or live in an environment.
-Scott
this is productive anchor for 'wifi for guests'
I need to build HA SSO.
which means it is not "CT5508-HA Unit", because "CT5508-HA Unit" should have no licenses, if I am not mistaken.
I need 50 licenses on one of two WLCs to build HA SSO?!
-Scott
