how to increase my WIFI rage mini 500 meter
ahmedmeall
Hi, my question is how to increase my WIFI range mini 500 meters actuality my home and office distance of 400 to 500 meters I am using the same internet service at home, and the office.
balaji.bandi
what model of AP ?
BB
Whilst you might be able to get an AP to send signal over 500m the issue is the client probably wont be able to reply.
Unless your talking a point to point solution to save having to run fibre between the two areas.
What you are better off doing is placing multiple APs to cover the area. I would suggest a site survey with tools like Ekahau
*****Help out other by using the rating system and marking answered questions as "Answered"*****
JPavonM
Is there a line of sight (LoS) between office and home?
The best solution would be to deploy a p2p solution as @Haydn Andrews propose, or mesh is there is clear LoS, and if the throughput is important, check a 802.11ad capable solution using 60GHz.
