Bookmark
Subscribe
869
How to make Cisco APs work as a repeater
haedongchan
hi guys
someone pls advise me that How to make Cisco APs works as a repeater
(example)
AP#1=========NEW AP#1(repeater mode)============PC
the signal of AP#1 is not enough to reach PC
So I want to set repeater AP in the middle between AP#1 and PC
Q1 : Does NEW AP#1 also need a LAN Cable ?? or just can work as a repeater mode without LAN Cable through the signal of AP#1??
Q2 : Detailed explanation and configuration will be very welcomed
Thanks guys
Arshad Safrulla
There are multiple ways to make this work. With controller and without controller, also there is a dependency on the wireless AP model and if you are running with the controller on the code as well. So provide some more information on your use case and your inventory.
Attaching the below guides
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-8/b_mesh_88/b_mesh_88_chapter_010.html
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215100-join-mesh-aps-to-catalyst-9800-wireless.html
