How to maximize wireless signal coverage on Aironet 2602i APs
Moule Ayalew
We just got 4 Aironet 2602i (standalone) APs and configured them to be used in our office (one on each floor ceiling). I guess we should have opted for the one with external antennas. Anyways, I would like to know
1. The default wireless signal coverage area for these APs (Aironet 2602i, with internal antenna)
2. How to maximize the coverage area (what should be configured? Optimize for range? Antenna gain?... or other stuff?)
3. Is it possible to use a wireless controller without changing the standalone image?
4. If not, is it possible to deploy CAP image on the APs, so that they can be used with the wireless controller?
Thank you
Stephen Rodriguez
So, a lot of this is "it depends", so I'll start with the two questions that have solid answers..
3.) No, if you want to use a WLC you will have to change the image away from the standalone image.
4.) Yes, you can convert the AP to use the CAPWAP image and attach to a controller
    Take a look at Rasika's blog posts.http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
now, for the "it depends"
1.) There is no 'default' as you are thinking of it, there are too many variables for there to be a 'default'. Now there is a default radiation pattern for the antenna that you can find in the data sheet for the AP.
  But default coverage...Data or Voice? what data rates do you need to support? How big of an area are you covering? How many devices will be on wireless? (devices not people)
  All of this goes into the formulae to figure out how much coverage you'll get from a single AP.
2.) a lot of the same in the above. What are you looking to optimize for?
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Scott Fella
There is no default coverage as it depends on the building construction  that will attenuate the signals
the only way to maximize the signal is to set the transmit power to maximum
No
Yes as long as you have the ability to download the lightweight image  this requires a valid smartnet agreement unless your Cisco SE or Cisco Vendor can supply you with the image.
You can try to download it here:
https://software.cisco.com/download/release.html?mdfid=284362257&flowid=34153&softwareid=280775090&release=15.3.3-JA1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
How to convert the access point can be found here:
https://supportforums.cisco.com/video/11928901/lwapp-lightweight-mode-autonomous-conversion-and-vice-versa
-Scott
-Scott
