Does AP BR1310g works with WLC 2504?
Hi All,
I have quick question here does AP BR1310 can be associated with WLC 2504?
Many thanks
1310 supported upto WLC 7.0.x code. So If you want to support that AP model your WLC should have older software code. This software code is not supported many newer AP models. Therefore if you have mix of AP models you need to decide which ones are more important.
See below (table 2) for more details
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ****
Adding to the above answers:
Yes it can be joined to a WLC it will only act as an AP, it will not be a bridge any longer.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
mohanak
Refer the link last supported OS version is 7.0.x : http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn76mr02.html#98367
Access Points
First Support
Last Support
1300 Series
AIR-BR1310G
4.0.155.0
7.0.x
