How To. OEAP a 2802
David Ritter
Level 4
Level 4
Ok, since the beginning, CAP's have been capable of functioning as OEAP devices.
I can attach to the public net, and get my enterprise SSID.  (configured from the WLC)
But can I make the 'AUX' port do anything?  Does the device in this mode provide any other feature such as private ssid?
I have plenty of OEAP602's and OEAP1810's so this is just an exercise in...  curiosity
TKS
Jurgens L
Level 3
Level 3
You can convert the AUX port to a LAN port which will then allow you to use the Dual RLAN Ports feature if this is something you require.
+++Please Rate Helpful Posts+++
thats one item I was thinking about. but I have not found any doc on the subject. I don't expect it in 8.3 code that I have my OEAP's on. I have lots of 602's.
