07-20-2012 07:14 AM - edited 07-03-2021 10:26 PM
In my WLAN enviornment there are multiple heavy, block walls. In some locations the AP may be stored securely in a closet while the antennas are routed through the ceiling and down into a room with concrete block walls. What I'm wondering is, how can I place the AP's antennas in a different location than the AP on a map in WCS?
Also in some locations I'm using a Yagi directional antenna, how can WCS take this into account?
Thanks for your help! -Mark
07-20-2012 09:05 AM
You can press on the ap on the map then chnge antenna orientation on the left panel.
07-20-2012 09:28 AM
I can change the up and down vertical position but cannot seem to put the antenna in a different area or room on the map.
