Need help getting 3500 AP to talk to WLC 2100
avrilsalter
I am trying to config my wireless lan controller (WLC) 2106 to discover my new 3500 access points.
I followed the example Cisco configuration doc. 69719.
I am using a Cisco 3760 switch to interconnect the AP and WLC.
I set up DHCP in the switch.
I update the sw on the controller
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.116.0
The ap is getting an ip address.
I can ping WLC to AP.
When I turn on debug events in WLC I get
(Cisco Controller) >*spamReceiveTask: Jul 17 22:34:04.255: 64:9e:f3:0e:a6:f9 Discovery Request from 10.5.5.142:60016
*spamReceiveTask: Jul 17 22:34:04.255: 64:9e:f3:0e:a6:f9 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jul 17 22:34:20.156: 64:9e:f3:0e:a6:f9 Discovery Request from 10.5.5.142:60016
*spamReceiveTask: Jul 17 22:34:20.156: 64:9e:f3:0e:a6:f9 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
no de*spamReceiveTask: Jul 17 22:35:58.058: 64:9e:f3:0e:a6:f9 Discovery Request from 10.5.5.143:60016
*spamReceiveTask: Jul 17 22:35:58.058: 64:9e:f3:0e:a6:f9 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jul 17 22:36:13.959: 64:9e:f3:0e:a6:f9 Discovery Request from 10.5.5.143:60016
*spamReceiveTask: Jul 17 22:36:13.959: 64:9e:f3:0e:a6:f9 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jul 17 22:36:29.860: 64:9e:f3:0e:a6:f9 Discovery Request from 10.5.5.143:60016
*spamReceiveTask: Jul 17 22:36:29.860: 64:9e:f3:0e:a6:f9 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 6, joined Aps =0
*spamReceiveTask: Jul 17 22:38:07.762: 64:9e:f3:0e:a6:f9 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '1'
*spamReceiveTask: Jul 17 22:38:07.762: 64:9e:f3:0e:a6:f9 Discarding discovery request in LWAPP from AP supporting CAPWAP
*spamReceiveTask: Jul 17 22:38:23.663: 64:9e:f3:0e:a6:f9 Received LWAPP DISCOVERY REQUEST to ff:ff:ff:ff:ff:ff on port '1'
*spamReceiveTask: Jul 17 22:38:23.663: 64:9e:f3:0e:a6:f9 Discarding discovery request in LWAPP from AP supporting CAPWAP
Does anyone know what the problem might be?
I really would appreciate some guidance.
Avril
6 Replies 6
Leo Laohoo
Can you please post the following outputs:
1.  WAP:  sh version;
2.  WAP:  sh inventory; and
3.  WLC:  sh sysinfo
Hello Leo,
I have attached the info you requested.
Except the WAP sh inventory -- because it shows nothing.
I discovered this bug + a problem with my DNS settings.
I now have the WLC sending a discovery response. But the AP is not responding.
Showing a DTLS fetal alert! So the secure tunnel is not set up.
I amwondering if it could be a certificate error, but I am fishing in the dark
I have attached new configs, error msgs, etc..
I so appreciate any direction.
Avril
What do you mean "it shows nothing"???
Kindly post the output to the following commands:
1.  WAP:  sh version;
I have had problems uploading files to this site for the past 16 hours. Not sure if anyone else has a problem
My problems was fixed. A combination of
- changing the WLC management and AP manager interfaces to native (and the same on the switch)
- applying this Cisco bug fix
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtw55476
Thank you Loe for looking it to this.
Avril
Sorry Leo -- I spelt you name wrong
Can force the AP to try on capwap.
AP#debug capwap con cli
AP#test capwap controller ip
AP#test capwap controller name
