02-11-2015 06:27 AM - edited 07-05-2021 02:29 AM
The following queries are in respect to AP High availability (not SSO fail over or Controller HA), meaning if one controller fails, the AP will be failing over to the secondary controller which is in a different Geo location. the AP will be in Flex-connect mode with local switching and local auth. in this scenario, following are my queries
1: If i have an SSID that has an interface group linked to it, can i fail it over on other controller where there may be a single WLAN linked to it.?
2:Do we need the subnet masks to be same at both ends?
3: if i have an SSID with open authentication, can i configure the remote network SSID with no authentication?
4: can any one link me up with a document that explains configuration case study of the flex-connect mode fail over scenarios.
All the help given would be really appreciated.
Thanks.
Solved! Go to Solution.
02-11-2015 06:47 AM
Interface groups only works for centrally switch not locally switch
See #1
if you configure an SSID with open authentication, then all APs that have that SSID assigned to it will use that. Open authentication is the same as no authentication.
Do a search on Google for "FlexConnect deployment guide". That will have links to failover.
-Scott
02-19-2015 05:09 AM
If you have WLCs in all sites, then my what you need to determine is if FlexConnect is really your best design. There are limitations to FlexConnect and to be honest, why have a controller in each site if your doing FlexConnect? All your data is locally switched, so you can actually bring all the wlcs back to your DC and have redundancy.
If you go with FlexConnect still, then how large of a subnet? You should create a subnet that is large enough for your clients devices today and for growth in the next few years. If the subnet is very large and you don't want to really have that large of a subnet, then FlexConnect isn't best for your design. FlexConnect is great for smaller sites so subnet size isn't an issue. /21-/23 shouldn't be an issue in my opinion, but you need to agree on that also. If they purchase an HA redundant for each site, now your converting the APs to local mode and then your cleaning up the configuration in all ap switch ports to make then an access port. That's a lot of work if you have many access points. It's very hard to answer your question without really knowing what's in place, what all the requirements are and what is the plan in the future. Hopefully I gave you some ideas.
-Scott
02-11-2015 06:47 AM
See #1
-Scott
02-18-2015 10:15 PM
hi Scott,
Sorry for replyimg late. and thanks for your reply and suggestion.
it did help me a lot, but now i am in a tiff.
the thing is my client has following existing scenario:
he has 6 disparate locations with a standalone 5508 WLC at each location.
he is now planning to configure AP failover for every location.
we are using the Flex-connect design as he has not procured a HA-SSO license.
also the WLC are not in same location.
the Flex-connect design is with Local Switching and local Auth.
there are 2 SSID which are causing me issues.
1: SSID A is linked to an interface group which has multiple vlans.
2: SSID B shares its WLAN interface with another SSID (the wlan is split between 2 different SSID)
we need local switching for these and also they need to have local auth.
so if i remove the interface group for SSID A and use a bigger subnet, what will be the best possible mask to use considering that the ARP and DHCP broadcast shouldn't choke up the network (existing subnets are /21 and /22). or any workaround to minimise the network activity.
and for SSID b what is the configuration i would need to do on the secondary controller or is it just that the SSID needs to be present on the controller and the mask need not be same.
sorry for troubling you and thanks in advance
Niiketan Sutar.
02-19-2015 05:09 AM
-Scott
02-25-2015 10:14 PM
thanks a lot scott...
have definitely got major pointers to work on following your advice.
02-25-2015 11:17 PM
a few more now:
1: when applying a flex-connect ap group config.. in general tab of group, we have a facility to add only 2 auth servers, what if more are required ?
2: how will we plan a failover if a single interface is attached to 2 different SSID.
thanks in advance.
10-25-2016 03:23 AM
Hi niketan sutar Sir,
Am in the Same Issue now.
2 sites having their 2504 controller and APs but customer want to failover these APs to HQ controller which is geographically separated.
when APs failover to remote controller it does broadcasts the SSID from remote controller but when client connect to it it only gets the IPs from the APs subnet (management in my case) not from the respective WLAN subnet ...?
(we have two Common WLAN and SSID at HQ and Site controller diff.subnets)
what i want is when APs failover to remote and it broadcasts common WLANs and when clients connects to one of them ..the user should get the IPs from the Sites respective subnet....?
is this possible to configure ...? if yes can you share how i can do this...?
10-25-2016 06:44 AM
Here is how it will be:
HQ Remote Site
AP-Group1: HQ_Group APGroup1: HQ_Group
AP-Group2: RS_Group AP-Group2: RS_Group
WLAN1 - mapped to VLAN: X WLAN1 - mapped to VLAN: X (Same ID)
WLAN2 - mapped to VLAN: Y WLAN2 - mapped to VLAN: Y
Put all AP in HQ in HQ_Group on HQ controller. Repeate the same on RS controllers for Remote site.
Also Create Flexconnect AP-Groups and MAP the Flex - WLAN's to their respective VLAN's accordingly. Ensure that the names are same and even cases of alphabets used are same.
basically, the configuration should be exact replica on both controllers with respect to AP groups.
also, ensure you have adequate number of AP license to accomodate both side access points on both controllers.
Hoe this helps...!!!!
for any further explainations, please dont hesitate to ping back !.!.!
10-25-2016 07:56 AM
Sir,
TAC has suggested something different or it is one and the same ...
here it is..
This is a summary of what we discussed:
To solve this issue follow these steps:
Please tell me how it goes. Feel free to contact me if you have any questions.
10-25-2016 07:11 AM
With FlexConnect, you need to make sure that your wlans are in the same order and configured the same way. If your using AP groups, make sure that the names are also identical and the configuration on the AP group is identical. You also need to look at what the SSID is mapping the vlan to and verify that local switching is either enabled to match the remote site WLAN setting or disabled. If centrally switching, then you need to ensure that you have sinners defend on HQ and interfaces defined also on the HQ controller.
What seems to be happening is when you failover, the HQ controller doesn't have the setting defined the same so the AP has lost the vlan mappings.
-Scott
10-25-2016 03:25 AM
Can i contact you by any other meas ..> Cell phone or email or WebEx or skype ..
awaiting for your valuable response.
10-25-2016 06:35 AM
hi pankaj,
i am accessible on sutar.niketan@gmail.com
i am based out of Qatar, my local number here in Qatar is +974 5029 4038.
I understand your issue and we can get it sorted out no problem.
What Scott has replied is exactly to the point of what needs to be done.
02-27-2015 09:57 AM
I have done the testing and got the same answer as scott.
Note:
Following is the doumentation for your review.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-product-00.html
