Wireless Flexconnection
rezende.c
Level 2
Level 2
Hi all,
    In Cisco Wireless Flexconnection solution, can you tell me the difference between "Web Authentication ACL"  and "Web Policy ACL" .
Claudio Rezende
WiFi Trainers
Level 7
Level 7
Hi Claudio,
There is very little documentation which clearly explains this. However this is what I found:
Web Authentication ACL is used when you are using webauth as your Layer 3 authentication policy and you are pushing an ACL for this.
Web Policy ACL is used when you are using any other form of L3 authenticaion like web-passthrough, conditional re-direct etc.
This link acts as a good reference:
http://www.cisco.com/c/en/us/support/docs/wireless/flex-7500-series-wireless-controllers/113605-ewa-flex-guide-00.html
Hope this helps.
Best Regards,
www.wifitrainers.com
Learn from the Best To be the Best!
Join us on LinkedIn to get access to our free tech-talks and training resources!!!
WiFi Trainers
Level 7
Level 7
Hi Claudio,
Hope this helps.
Best Regards,
