09-25-2013 08:49 AM - edited 07-04-2021 12:56 AM
My customer is running 5508's with AP groups.
So that new AP's don't transmit the SSID's before I'm ready, I've enabled the 'Out-of-box' feature, which places the AP's into a new group, which is system configured with the radios disabled.
I just then need to move those AP's into the desired group when I'm ready for them.
Question is, how do I get the radios to switch back on?
I've moved them into the desired AP Group and they rebooted as expected, but both radios are currently down.
I went into the radio configure page and 'enable' is already selected, but they refuse to come up???
I'm running 7.5.102.0
Dan
09-25-2013 08:55 AM
They should come back up unless you have the radios disabled globally unders the Wireless tab > 802.11a/n and 802.11b/g/n.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
09-25-2013 02:15 PM
Did you check individual AP radio interface status? (Wireless -> Radio -> 802.11b|802.11a) , Ensure it is not in "disabled" status.
In WLC CLI, you can check it as below. In my case 2.4 radio is disabled & that's why it says ADMIN_DISABLED & DOWN. See what is the output of this in your case.
(WLC) >show ap config 802.11b
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Attributes for Slot 0
Radio Type................................... RADIO_TYPE_80211n-2.4
Administrative State ........................ ADMIN_DISABLED
Operation State ............................. DOWN
Operation State Down Cause................... Radio Admin State Change
Operation State Down Code.................... AP_IF_TRAP_CONFIG_RADIO
(WLC) >show ap config 802.11a
Attributes for Slot 1
Radio Type................................... RADIO_TYPE_80211n-5
Radio Subband................................ RADIO_SUBBAND_ALL
Administrative State ....................... ADMIN_ENABLED
Operation State ............................. UP
Radio Role .................................. ACCESS
If you want to enable it via CLI you can use following
config 802.11b enable
config 802.11a enable
Rasika
**** Pls rate all useful responses ****
