How to recover AP that's no longer visible in controller after bridge mode enabled?
wifiguy1000
How to recover and troubleshoot an AP that was changed to bridge mode and subsequently lost connection to the controller?  Tried toggling switch ports to force reboot, however unsuccessful.  Curious if there's a solution without having to manually get to these APs.
Thanks!
Hello Jhon.
Don't worry just need to add the AP's mac address to the controller and they will be back wink
Click Security tab --> AP Policies --> Add the Mac Adress
**Please rate the answers if it was useful**
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
6 Replies 6
Hello Jhon.
Sandeep Choudhary
In order to configure the bridge in Local Mode, complete these steps:
Go to the WLC GUI and choose Wireless. It displays the list of APs that are currently registered to the WLC. Click on the AP for which you need to change the mode.
Check the option AP mode. If it says Bridge, then change it back to Local. This changes the Bridge AP to Normal AP.
Dont forget to rate helpful posts
Hi Sandeep,
    Thank you for your response.  The problem is that the AP's that were changed to bridge mode are no longer visible on the controller, and unresponsive to pings.
Jonh
did you see my post?
You need to add the Mac Address of this AP. and it will be rejoin to the controller?
You can add from Security Tab --> Ap Policies.
Hi D,
   I saw it, I was just waiting for my colleague to try it remotely.  It worked, its always something simple isn't it :)
Thanks again!
   John
You're Welcome wink
