Setting up Aironet 1600
melissa.jaffray
We just got a 2500 controller and three of the 1600 aironet access points. I have the controller setup but I can't get the access point to connect to it. I have tried plugging it in to the PC and it asks me for a username and password when I go through the serial port. Any help will be extremely appreciated. I really just need to give it a static IP and I'll be all set. Thanks!
LJ Gabrillo
Level 5
Level 5
There are two types of APs LWAPP and Autonomous
If you need to integrate that to the WLC you need to convert it to LWAPP
To verify, you need a console cable and access the CLI through Console
Default creds is : Cisco/Cisco --capital C
IF:
<mac-address>:    -LWAPP
ap:                           -autonomous
Check the cisco documentation about converting Autonomous to AP (google will do the trick)
With regards to joining your AP.
I would recommend that you assign your APs statistically, there are many ways you can do this
1. Create a DHCP Pool and once the APs join assign them
2. Invoke through CLI
Since those are just 3 APs I would suggest invoking it in the CLI, here is how to do it:
#capwap ap ip address <IP> <NETMASK>
#capwap ap ip default-gateway <IP>
#capwap ap ip controller ip address <WLC-IP>
#show capwap ip config       -to verify
If you want video tutorials, check this youtube result: https://www.youtube.com/results?search_query=adding+APs+to+WLC+cisco
LJ Gabrillo
Level 5
Level 5
IF:
ap:                           -autonomous
Lsgabrillo is right. First you need to be sure that you are using lwapp instead of autonomous. I had this problem too and the problem was that my 1240 ap was autonomous so I had to converted to lwapp and then the aps was able to download the image from lan controller
Hi Melissa.
What image are using your AP's?
Check this link, maybe it help to understand the AP's images.
http://www.my80211.com/cisco-auton-labs/2011/11/19/understanding-cisco-access-point-ios-images.html
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
melissa.jaffray
Thank you so much for your fast answer. One of them had the issue but the other two connected right away. Thanks!
