https trouble with WLC-4402-50
james-mccarthy
I have a WLC4402 and all of a sudden I can't login through the interface I have been using for a couple years. I get the Certificate popup asking to accept the cert and as soon as I click Yes it gives me a "page cannot be found". I can log in through other interfaces though.
Thanks in advance for any help you may be able to give.
20 Replies 20
Ok. I'm fine with using the management interface. And am I understanding that it's ok that the certs are off by 20 years? when I click the cert accept page it says the cert is not yet valid.
Is the system time on the WLC correct?
-Scott
Same question I asked a bit ago. If the time is correct then TAC will have to get involved unless you time server (if configured) is wrong. Other than that, the unit itself probably has a problem.
Sorry, I forgot to mention that the clock is correct. day and time are both correct and as far as I know, our NTP servers are also correct. And both units have the Certificate problem with not being valid for 20 more years.
You have all been a great help so far. Thank you.
In the immortal words of E.T. "Call HOME!" ie call TAC. You have a real life situation lol. I haven't seen this in nearly 2 years.
HAHA, yeah I had a feeling this wasn't going to be simple. The best thing about it is this: I can't log into the management interface UNTIL I accept the certificate on the other interface first. If I don't do that, it just times out. I think Murphy's law has been applied to me all month.
Thanks again for all your help.
