https trouble with WLC-4402-50
james-mccarthy
I have a WLC4402 and all of a sudden I can't login through the interface I have been using for a couple years. I get the Certificate popup asking to accept the cert and as soon as I click Yes it gives me a "page cannot be found". I can log in through other interfaces though.
Thanks in advance for any help you may be able to give.
In the immortal words of E.T. "Call HOME!" ie call TAC. You have a real life situation lol. I haven't seen this in nearly 2 years.
20 Replies 20
Scott Fella
I have seen this issue if you have an interface on the WLC that is also part of a wired LAN subnet. Make sure you separate your wireless subnets from your wired subnets.
-Scott
we do have interfaces on the WLC that are also on the wired LAN. Different interface IP's. The problem is that it was working fine for a couple of years and just stopped working a week or so ago. We are also using software version 3.2.195.10. I think this problem may have started when we updated the software.
I could be that the upgrade caused the issue. It is still best practice to seperate the two. I have ran into that issues with the 4.0 and 4.1 code.
-Scott
mprofitt1967
Frequent Visitor
Frequent Visitor
Can you telnet or ssh to the controller?
Yes I can SSH and telnet to the controller. It's just https that won't allow a connection.
ssh to the controller and try this...
>show network
to see if secure web mode is enabled, if not
>config network secureweb enable
When you try to https, are you on the wired or on the wireless. There is an option to allow or not allow wireless management. Also I you do have disabled and you are wired and on wireless, it will not work. Verify you can get to the WLC (https) from only a wired laptop or pc.
-Scott
-Yes the Secure Web Mode is enabled.
-And yes I am on wired. I do have the allow wireless management option enabled. I can log in through https on other interfaces but not the interface I have been using in the past.
What I meant is make sure you are on the wired, but you don't have your wireless on. also the interface you should be able to https to is the management interface.
-Scott
Yeah I have the wireless off. And I can access the management interface through https. But we had a seperate interface using the IT VLAN to allow us to manage the devices without giving access to the entire management VLAN. It's not a huge deal that I can't log in using that interface since I can still manage the devices using the management interface. I was just curious as to why it would work a couple weeks ago and just stop all of a sudden. I'm leaning towards the possibility that the recent software upgrade is responsible for this.
James,
Have you rebooted the WLC? There is a known issue with a corruption of the session as it relates to the certificate on the controller. It was caused by a memory leak I think. Anyway, try rebooting the box. That usually fixes the problem.
Dennis
Yeah I rebooted it twice already. I even tried to regenerate new certificates. Here's the funny thing though, it says the cert is valid from Nov 8th 2027 through Nov 8th 2037. I'm not an expert on Certificates but this doesn't seem normal.
Nope. Check the date and time on the controller. If the date and time are correct you will need to open a tac case as the certs are way off on the timestamp piece and will need to be rebuilt.
That is how the certificates are in the WLC. The only way I can see that you once were able to manage via the IT VLAN to the IT VLAN WLC Interface is if you had manage via wireless enabled. With the 4.0 and the 4.1 I know for sure you can't access other interfaces other than the management.
-Scott
