Impersonation of AP issue
gbressanin
i have a WISM with release 6.0 and 150 AP connected all in the same RRM. In the TrapLog I see a lot of |"Impersonation of AP......" messages. This issue is between AP connected to the same WISM and in he same RRM.
Any idea?
Giovanni
An
Do you have "AP Authentication" enabled under Security>WPS>APAuth/MFP ? If you do, try disabling it (on both controllers)
Roman
8 Replies 8
Roman Rodichev
Level 7
Level 7
Do you have "Validate SSID" checked under WLC > Security > Wireless Protection Services > Trusted AP Policies?
In my WISM with revision 6.0 installed I don't find the "Trusted AP Policies" under "Wireless Protection Services".
I attach the copy of the security web page.
Bye
Giovanni
Is this happening for one specific AP or for many of them?
For many of them.
Roman
Hi Roman,
thank you, it was the " AP Authentication Policy" configured as "AP Authentication that generate the error messages. Now I set the Protection Type to " Management Frame Protection" and I not get any error messages.
Thank you again.
Giovanni
Giovanni,
Interesting, that means:
1. Your two controllers don't have matching RF Group names. Double-check.
2. or you could be running into a bug
MFP is definitely a better option :)
Roman
Hi Roman,
sorry for the late but I'm in vacation. I read now the answer at the case that I opened to the TAC about this issue.
From the case notes which you have added, I can see that you are affected by the bug:
CSCsi18369
AP Auth: Known rogues are reported as impersonation alerts
Symptom:
If AP authentication is enabled, the controller will report the entries in the known AP MAC address
list, as impersonation alerts.
Workaround:
Use MFP or disable AP Authentication
Giovanni
