In cisco 3650Switch not able to add AP
Dear All,
We have configured cisco 3650 switch and I am not able to add the AP, once I connected the AP, I am getting below attached error. Kindly advice
*%CAPWAP-6-DTLS_CONN_ERR2:Switch 1 R0/0: wcm: DTLS connection not found for AP 192.168.30.2 (5256), Controller: 192.168.30.1 (5246) dtls payload
*Nov 28 09:19:02.596: *%DTLS-3-PKI_ERROR:Switch 1 R0/0: wcm: PKI initialization error : Certificate initialization failed
*Nov 28 09:19:02.597: *%CAPWAP-3-DTLS_DB_ERR:Switch 1 R0/0: wcm: 0000.0000.0000: Failed to create DTLS connection for AP 192:168:30:2 (5256).
*Nov 28 09:19:04.497: *%DTLS-3-PKI_ERROR:Switch 1 R0/0: wcm: PKI initialization error : Certificate initialization failed
*Nov 28 09:19:04.497: *%CAPWAP-3-DTLS_DB_ERR:Switch 1 R0/0: wcm: 0000.0000.0000: Failed to create DTLS connection for AP 192:168:30:2 (5256).
9 Replies 9
Mark Elsen
 - Check wether the 3650 runs a sufficient software release which is compatible with the AP model.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Dear Marce,
The switch has 16.3.5b software.
kabeer
You didn't write which AP model.
Here the release notes and list of supported APs:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-3/release_notes/ol-16-3-3650.html#64952
Hi Team,
I checked the AP and its supported that version and I am using same model in other site but it works fine but this one I am facing this issue.
Nov 28 05:39:00.216: *%DTLS-3-PKI_ERROR:Switch 1 R0/0: wcm: PKI initialization error : Certificate initialization failed
Nov 28 05:39:00.216: *%CAPWAP-3-DTLS_DB_ERR:Switch 1 R0/0: wcm: 0000.0000.0000: Failed to create DTLS connection for AP 192:168:30:8 (8451).
Kabeer
Dear team,
Could you please update about the below issue.
Thanks in advance.
Kabeer
Dear Team,
Any one update on my below request
* *%CAPWAP-3-DTLS_DB_ERR:Switch 1 R0/0: wcm: 0000.0000.0000: Failed to create DTLS connection for AP
Kabeer
Sorry I don't know this error.
Could you attach a console cable to the AP and reboot it and then please post the complete output here?
Dear All,
I am not able to add  any AP, I tried with different model and I am getting same error I consoled to the AP and I am getting below error
Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*11/30/2018 15:14:58.4384] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*11/30/2018 15:15:54.0166] CAPWAP State: DTLS Teardown
[*11/30/2018 15:14:57.0000] CAPWAP State: DTLS Setup
Time is correct in the switch and Country supported also correct but still I am getting same error. Could any one advice pls.
Kabeer
Please provide the full boot log of the AP. Sometimes we can see something more further up.
But maybe the WLC has some certificate problem on the 3650, but I don't know how to troubleshoot that model.
