In need of help with IOS recovery for Cisco Aironet 1530I
terrill.coleman
I have this AP that the IOS got fried or corrupted. Either way, I have attempted an IOS recovery but nothing I have tried is working.
I have tried recovering via tftp, but the connection either times out, or just gives me "permission denied" message.  Here is the startup for the WAP. Maybe someone can help steer me in the right direction.
System Bootstrap, Version U-Boot 1.1.4--LSDK-9.5.5.4-gf5ee82b1-dirty Corfu , REL EASE SOFTWARE
Build Date: Feb 24 2014 - 17:43:32
corfu - Scorpion 1.0
DRAM: 256 MB
Now running in RAM - U-Boot at: 8ffbc000
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x14
flash size 1MB, sector count = 256
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Commu nications, Ltd.
Ath Nand ID[8ffee17c]: 2c:f1:80:95:02
ONFI MICRON MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
size = 128MB
boot_method is set to IOS_BOOT, boot IOS bootloader in NOR flash
Loading .text @ 0x84000000 (208000 bytes)
Loading .rodata @ 0x84032c80 (39072 bytes)
Loading .data @ 0x8403c520 (3264 bytes)
Loading .data.rel.local @ 0x8403d1e0 (1084 bytes)
Loading .data.rel @ 0x8403d61c (124 bytes)
Loading .data.rel.ro @ 0x8403d698 (960 bytes)
Clearing .bss @ 0x8403da60 (161116 bytes)
Clearing .scommon @ 0x84064fbc (56 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.HW Test Status(0)
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 197
total197 197
success found all blocks
start end 147 207
found in range
high low end 6628 4709 207
Xmodem file system is available.
mifs[0]: 30 files, 5 directories
mifs[0]: Total bytes : 131334144
mifs[0]: Bytes used : 14839808
mifs[0]: Bytes available : 116494336
mifs[0]: mifs fsck took 0 seconds.
Base Ethernet MAC address: 70:e4:22:ce:fd:36
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 0 Negogiation timeout.
Ethernet link is down.
Scorpion ----> F1 PHY *
: cfg1 0x7 cfg2 0x7114
Loading "flash:/ap1g3-k9w8-mx.153-3.JC14/ap1g3-k9w8-mx.153-3.JC14"...################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
bad mzip file, uncompressed to wrong length , (0x24c5b4d != 0x24c7860)
Error loading "flash:/ap1g3-k9w8-mx.153-3.JC14/ap1g3-k9w8-mx.153-3.JC14"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
ap1g3 Boot Loader (ap1g3-BOOT-M) Version 15.2(4)JB3b, RELEASE SOFTWARE (fc1)
Compiled Thu 23-Jan-14 21:52 by prod_rel_team
ap:
5 Replies 5
Refer below document & see if you can recover it
https://community.cisco.com/t5/wireless-mobility-documents/cisco-aironet-access-points-ios-recovery/ta-p/3123138
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
DO the following:
1. flash_init
2. dir flash:
terrill.coleman
All of you who sent links, thanks for the input, but I had done those things already. The AP ended up dying, so I am sending it back as an RMA. I will get a replacement soon.
Glad to hear the kit is replacing now.
BB
