Incorrect power injector
Javier Zamora
Visitor
I have purchased several AIR-LAP1242AG-E-K9 but had no POE switches so I needed power injectors; we ended up purchasing AIR-PWRINJ-FIB without noticing that they were also media converters.
Is there any converter I can use to convert back to copper? I wanted to confirm this before getting to the inevitable conclusion that we need to exchange them for the AIR-PWRINJ3
Federico Ziliotto
Hi Javier,
You may want to take a look at the following media converter:
http://www.cisco.com/en/US/prod/collateral/video/ps8806/ps8900/ps8901/product_data_sheet0900aecd806c4982.pdf
Hope this helps,
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Thank you very much for the prompt response. I will be sure to read up on this converter.
Thank you Javier, glad this can be useful 😉
Feel free to ping us back in the future in case any further assistance would be needed with your wireless setup.
Fede
