Industrial Wireless IW3702 DNA license
Anwar Safian
Hi expert
I would like know
1) Whether Cat 9800 wireless controller can support IW3702 because  IW3702 doesnt have DNA license when I configured in CCW
2) How to select number of AP license in Cat 9800? Is Cat 9800 only work for AP that have DNA license only?
1. Yes, 3700 series is supported in 9800 WLC
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/release-notes/rn-16-10-9800.html
2. You can go with "AIR-DNA-x" as explained in below. 9800 work with smart licensing, so as long as you have AP licences on your smart licensing ports that should work.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/guide-c07-742134.html
Rasika
*** Pls rate all useful responses ***
Hi Rasika
Thanks for your great explanation
However, I am not planning to use DNA.
I am going to use Cat 9800, IW3702 and prime infrastructure.
So, how should select number of AP license in Cat 9800?
Example for WLC 5520, there is separate SKU for ordering AP license, but i dont find any for Cat 9800
Even you do not plan to use DNA-C (appliance), you have to choose that DNA subscriptions as that is how licensing work. Two types  of licensing tiers "DNA-Essential" or "DNA-Advantage"
Rasika
