Ingress Protection Rating for Cisco Access Point 1850
ciscodinhnhat
Hi Experts,
Do you know any information about Ingress Protection Rating (IP) of Cisco Access Point 1850  ?
I cant find any docs online mentioning about this Access Point.
I only can find Cisco Access Point 15XX , which has IP67
Thank you very much
Leo Laohoo
15XX are designed for OUTDOOR use.
The 18XX is designed for INDOOR use.
If the AP is going to be exposed to water ingress then 15XX is the way to go.
Hi Leo,
Understood. But I just want to look for IP number for Cisco AP 1850??
Do you have any info on that?
Don't think they have one, because they are not intended for environments where that matters.
I think you have to look at it this way. If there is no ip rating, then it is not rated for any. This is the same for any device out there.
-Scott
