inquiries for WLC 3504
Ahmed Tarek
Level 3
Level 3
hi all,
i have some inquiries for WLC 3504
- how can i get current TLS version applied on WLC ?
- how can i get current SSL version applied on WLC ?
- what is recommended version for SSL now and TLS ?
- when i access WLC GUI i need to install certificate ( self sign ) how can i install it from CA?
- after apply new TLS and SSL versions, it mean old versions is off ? or i have to disable them manually ?
thanks in advance
2 Accepted Solutions
marce1000
 - FYI : %   nmap --script ssh2-enum-algos  controller-hostname
            %  nmap --script ssl-enum-ciphers -p 443 controller-hostname
  In general , if you are worried about security issues concerning TLS/SSL then upgrade the controller according to :
               https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
                              and review the situation again ,
 M.
Rich R
- Upgrade software to 8.10.190.0 (or later as per TAC recommended link below)
- Ensure WLC is configured for maximum security options as per the config guide:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/administration_of_cisco_wlc.html#ID520
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/administration_of_cisco_wlc.html#hsts_policy
- Update the certificate as per the guides:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/managing_certificates.html
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/215425-troubleshoot-certificate-installation-on.html
10 Replies 10
marce1000
 M.
Ahmed Tarek
Level 3
Level 3
hi @marce1000
what are these
are they command i need to type in CLI ?
sorry but i need to understand
 - nmap is hacking tool ; you can download it from https://nmap.org/    but for your purposes you can consider yourself being an ethical hacker ! (You can install nmap on a windows on linux host ; the commands must then be executed from where nmap was installed)
 M.
Rich R
Ahmed Tarek
Level 3
Level 3
thanks @Rich R for your links,
but is there any command i can check current TLS version from CLI or GUI for WLC 3504 ?
all commands i found related to other WLCs
Not specifically - refer to Marce's answer for how to check that.
On the WLC you can use:
grep include "Secure Web" "show network summary"
to check the configured settings but that won't show you TLS versions explicitly.
Ahmed Tarek
Level 3
Level 3
thanks @Rich R,
show network summary show the following
Secure Web Mode............................. Enable
it mean what ? which TLS version is applied ? 1.1 or 1.2 or 1.3 ?
As I already explained it does not tell you the TLS version(s).
Refer to Marce's earlier answer for how to check TLS versions!
That line just tells you that https is enabled.
The lines you're more interested in are "Secure Web Mode Cipher-Option High" which should be Enable and "Secure Web Mode SSL Protocol" which should be Disable.
Ahmed Tarek
Level 3
Level 3
i can not use his commands, is not allowed to use this in my environment.
i hope now you can get what i mean
Then it is impossible to do what you want.
