Installing rails on MSE 3310
spfister336
Level 2
Level 2
I've got an MSE 3310 that came with four-post rails for rack mounting. These came without instructions and we are having a hard time figuring out exactly how they work. Any help or links to how to use them? They say General Devices C-300-S-124-RC-MOD
maldehne
Please Check :
http://www.cisco.com/en/US/docs/wireless/mse/3310/quick/guide/MSE10_c4.html
Please Don't Forget to rate correct answers
Rob Huffman
Hi there,
This is the install diagram I could find;
http://generaldevices.thomasnet.com/Asset/INST3000-A%20%28C-300%29.pdf
From;
http://generaldevices.thomasnet.com/item/solid-bearing-slides/c-300-rev-c-br-non-pivoting-slide/pn-1476
Cheers!
Rob
"What you don't have you don't need it now"
- U2
Thanks... I've run across this diagram before, but I'm not sure how to apply it. The parts don't seem to want to separate.
maldehne
Please Check :
I think I'm almost getting it... do I push down on the small tab on the innermost section when the slide is fully extended?
